Topic: Clutch Position Switch (Read 1095 times) previous topic - next topic
Afternoon All !!
Has anyone ever messed-around with the "Clutch Position Switch" ??
I'm still having my Engine Running Problem...it has morphed into Bucking -n- Jerking at most any time.  (Yes... I've replaced the TPS)
But what has caught my attention... as I've disengaged the Clutch, to stop the engine from bucking (and such) the engine smooths-out and runs fine.  After noticing that fact... I have learned that only depressing the Clutch Pedal a Fraction of an Inch... Everything settles-down and runs fine.
According to my drawings  that switch is in a similar circuit with the Neutral Safety... but only wired in Series with that.  I was attempting to find a method of 'shorting out' the two wires to see if that make things right.
.. .. any ideas would be Greatly Appreciated !!
Never mind....
I got to the connector I wanted to  :D
.. attempted the 'work-around' to see what might happen
Nothing changed... :evilgrin:
