Topic: 331 stroker build in the making CAUTION BIG PICS!!! (Read 9814 times) previous topic - next topic
Quote from: Dan B.;413421
Didn't do this with my T-bird but DID do it with my Ranger.  It's had a 351W in it for 15yrs.  Going to yank it today to drop in a 387W built on a Lightning block!!
You sir, have became my goled hero, lol.
Gonna post a few pics of it? There's a few of us wouldn't mind seeing, I'm sure ;)
Quote from: ThunderbirdSport302;413427
Will start a new thread.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Nahh not going to deck the block it only had 30k miles on it and in my opinion unless I was going full race it's a waste
'88 cougar 331 supercharged build in progress
'95 Blazer solid axle swapped 4X4- daily driver
Not a waste at all, the more square things are the better over the long haul.  If you have access to the machine and its basically free it is well worth while.
Darren
True
well we dont have a decking machine once its mocked up ill check deck height and see what it is
Kudos for you sense you built this in ten degrees!! Badass block dude how much horse are you expecting from it?
Just a question!!! Why no deck plate??
well this isn't a boring machine is a honing machine plus i was doing small passes .005 at a time and plenty of coolant and cool down time before the final finish
Quote from: 5.0thunderbird;413567
well i saw a similar set up run 385 at the crank im hoping for at least 450 with all the other goodies
Quote from: supercharged88;413667
I'd like to dyno mine to see what I make, if you dyno yours I'd be curious to see the results. I'd like to see mine over 400 hp but I have no idea, needs a tune for sure.
yes it's a honing machine instead of boring them out they hone they cyliners with diamond stones.
all notched out for the stroke of the crank
X
Cam is installed with bearings and thrust plate .006'" end play
X
main studs and crank installed with clevlite bearings .002" clearance (platigauge)
X
also installed new brass freeze plugs and rod bearings and pistons going in this week
Looking good
