Topic: 88 XR7 no dash at all help!?!?! (Read 5147 times) previous topic - next topic
The part is probably obsolete, so you won't find it at Autozone. I forget where I got the one for my old Sport. Here's a pic of where it's at. This image is of the left hand side of the dash and would be looking at the dash from the firewall side, with the steering column coming down through the center (you can see the column support bracket in this pic).
X
The section of the ignition switch that feeds the "green wire" to the Alt. Reg, also feeds fuses 5, 9 and 17.
Fuse 17 powers the electronic cluster.
With the "green wire" jumpered to 12 volts, it backfeeds through the Alt. warning light, all the stuff the ignition switch should feed but at a reduced voltage.
Don't know what relay you replaced.
The ignition switch on the steering column with a lot of wires to it, not the tumbler you put the key.
And as Foe said, replace the ignition switch (and the connector). This is why you have to turn the key just right to get other things to work (turn signals, HVAC, etc). Until you do this, disconnect the battery. I have gone on about this before, and it may sound like I'm being alarmist, but your car is a ticking time bomb. Your car could catch fire at any moment, whether you're in it or not. It doesn't matter what position the key is in, or even if it's in the car - it could go up in smoke at ANY MOMENT!!! Disconnect the battery. Now. Do not reconnect it, and do not drive the car, until you get that switch replaced! I go on like this because I had one catch fire on me. While driving...
okay!  I got the ignition switch. and the panel relay is the one i replaced. it is called the ignition relay btw...
okay i assume the ignition switch is where the key is right? otherwise where is it?
Quote from: TheFoeYouKnow;413151
You'll very soon see why so many of us are always talking about "slaving" circuits.
wait what?
I got it put on but the dash is still pretty hard to see. I will try it now that it is dark...  I bet I have someblownbulbs...
Also make sure both plugs are attached securely to the dash.
Quote from: Kitz Kat;413173
They are...
what are you talkinga bout slaving?
Nothing that has any bearing on your current situation.  But because you want to know, it's the act of using relays to route current around the ignition switch, and by so doing,  actively prevent component overheating.  But THAT will be a project for another time, you have to get things working before you start thinking about slaving the ignition switch.
Speaking of the switch, you replaced it, but what did the connector look like?
I am thinking of using LEDs in the dash to make it very bright, because when I flip the headlight switch on, the stereo and blower control and everything but the gauge panel light up at night.. so i have no night time gauges right now...
try moving the rheostat wheel next to your headlight switch back & forth a few times. That sometimes gets bad contacts and causes no backlighting when the headlights are turned on.
Quote from: Thunder Chicken;413265
just in the dash though? i mean all the other lights work...
Quote from: TheFoeYouKnow;413268
Well, thunder chicken, he's got you there.
I still think we'd like to see a pic of the ignition switch connector.
ill grab it when im off work in 2 hrs :)
