Topic: Polished up the Mustang TRX's on my Gray Bird (Read 4784 times) previous topic - next topic
I remember when you first posted about the wheels, and they look beautiful polished. I would love to do this to a set, but know nothing of how to make the center and ring work, let alone where to find the outer wheel for it. Any suggestions?
Quote from: cougrrr302;413386
The wheels are Center Line billet wheels.
The T-Bird/Cougar TRX's will not work inside 15 inch wheels. ( can only use 16's and 17's )
You would  have to install 3 inch long wheel studs all around as the centers are attached with a second set of lug nuts.
There is a black  Mr. Gasket 4 lug dust shield for 15 inch wheels behind the TRX center to hide the C/L wheel.
You would also need to find a machine shop that could put the rough cut TRX centers in a lathe (apprx. 14.5 inches in diameter)
I just took the Center Line wheel with me to the machine shop so they could check the center for a close fit.
The hardest part was cutting the front and back off the wheel to get the rough centers:
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Here's a pic of the maroon TC with the 16 inch Center Line before and after the TRX center is attached:
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
That stance is awesome!!! What size tires are on the front of the 460 car?
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Quote from: Dan B.;413529
Thanks.
The Gray Bird has 215-60-15 front tires on 15 x 7 wheels.
The rear tires are 295-50-16 M/T Drag Radials on 16 x 8 wheels.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
That's pretty trick
Quote from: 83-88T-Bird Guy;412306
Well, after racing my 83 T-Bird for 2 years with the 2500 grit satin finish look on my wheels I thought I would spend a couple of hours polishing them to see how they would turn out.
I really like the polished look better.  :ford:
I still find it hard to believe that come September, I will have had  the ol' Gray Bird for 20 years.
I always liked TRX Wheels, and polished up they look really super. I'm still waiting to hear what tires you have on them!
Ron
Speed is just a question of MONEY How fast can you go?    (M. M.)
Quote from: BLKBRD88;413603
Ron
Thanks.
On the gray Bird, the rear tires are 295-50-16 M/T drag radials.
The fronts are standard 215-60-15 street tires.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Quote from: 83-88T-Bird Guy;413749
Thanks.
So are you going to let us in on your secret of how you got those 15"/16" tires mounted on metric wheels?
Quote from: STANG8U;412331
Wow never liked those ....... But now I do lol
Looks  good
I felt the same way, he made them look good!!!
Quote from: BLKBRD88;413767
Not being a smart@$$ but read the whole thread or at least scroll thru the posts for the pics. He explains it well and shows what he did.  See page 2, #s 13 & 14, metric centers, longer studs, some machine work waa-laa, shiny wheels.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Quote from: 1BadBird;413779
There you go, I must have had a senior moment & skipped page #2  DUH
Ron
