Topic: Horsepower Question?? (Read 2412 times) previous topic - next topic
Quote from: Haystack;412216
Read coolcats.net on the h.o. conversion/swap. He touchest on the 83-85 engine setups. If you found the right parts, you could do it in a weekend..
Thanks for pointing me to Coolcats.  Interesting read on the CFI to Carb mod.  Linkage mods for carb and AOD shift linkage could be beyond my skill set.  Sounded tricky and alot of trial and error to get them right.  However, considering the potential hp gain and the fact that it would retain "stock" appearance it is worth serious consideration.....likely take me a little longer than a weekend but no hurries here.  Thanks.
Quote from: TurboCoupe50;412217
I can appreciate your wanting to stay stock appearing on a 30th anniv, I would want to do same....
There are three major ways to do this, all would include a full free flowing exhaust system of at least 2.25" and headers... Heads on pre '86 engines are similar to the E7, I would not swap those unless you're going GT40 or similar...
#1 swap to a more HOish cam(This isn't a roller engine so all you guys forget stock HO cam) and a HO CFI setup from a '84/'85 LSC or AUTOMATIC Stang... I believe those were rated at 165Hp, and the exhaust system should add another 15-20Hp... Except for the exhaust system, stock appearance is retained... Bad the stock HO CFI is hard to find and 30 year old electronics can(maybe will?) be buggy...
#2 would be same as above but use a 600 CFM or so carb and decent flowing intake, would still be close to stock appearance... You would also need to swap to a low pressure fuel pump to feed the carb...
#3 Full SEFI swap to a '87 up system, still could use your heads but would still have to figure out a cam as I stated prior this isn't a roller engine...
Note there is a possibility it is a roller block(anybody have a list of the casting numbers?), I've seen late '85s that used them but the spider hold down was not drilled and tapped...
Thanks.  I like the sound of option 1 but want to make sure I understand.  Are you saying by swapping the stock cam to an 84/85 LSC/Mustang HO cam that I should see around 165hp or about a 25hp gain over stock?  And then additional hp gains with the exhaust mod?  I thought the 84/85 Lsc/Mustang setups included the dual exhaust set up so would the 165hp be total?  Thanks for your help.
Quote from: Aerocoupe;412214
Do a full header back dual exhaust and you will notice a huge difference.  My 83 was a stock 5.0 with CFI with an AOD and all I did was put a full exhaust in it (granted this was back in 93ish) and I remember it being a huge difference over stock.  Even though your car is an anniversary edition car these cars do not have much of a monetary value to the public like the Mustangs so keeping it stock typically only brings an appreciation from the owner and a very small crowd of people.  Read this thread as we are currently helping another member (at least I hope we are helping) figure out what to do with his SO setup:
http://www.foxtbirdcougarforums.com/showthread.php?35557-Talking-cylinder-heads.
Yours would be pretty much the same but like someone else already mentioned just get a carburetor (600 CFM with vacuum secondaries are easy enough) and a good intake and you would be set.
Darren
Thanks.  Any idea what you gained in hp doing the full exhaust mod?
Quote from: birdman85;412292
Yes the early HO cam would be the way to go...
None of the pre '85 HO had a true dual exhaust(actually '86 was first), '85 5-speed had headers, others had cast iron exhaust manifolds and single systems... Assuming the CFI HO setup made 165Hp, you should gain another 15Hp from the headers and free exhaust system... Problem is I don't think it's possible to verify without removing the heads... Problem is I don't think the head number can be verified without removing the heads...
BTW if your block casting number begins with E5AE, it is roller cam compatible, but likely the lifter spider hold down bosses are not machined or tapped for bolts... E5AE should also be the head casting number, which are the same ones used on the carbed 210HP '85 5-speed Stangs...
