Topic: Subframe connectors (Read 9478 times) previous topic - next topic
Subframe connectors
Quote from: Big B;411906
Awesome design Daminc. How often do you get to see a Unibody car jacked up from the side like that so easily, lol.
You fab that yourself?
Every time I jack my car up
Subframe connectors
Quote from: daminc;411924
Yes, I made just about everything that went into my car, including the new front frame sections
Impressive Work!
Subframe connectors
Quote from: Kitz Kat;411940
If you jack it up just right I had 3 wheels up on mine.
I keep saying I have to try that. when I finally remember, I'll probably forget to take a pic...lol
Subframe connectors
daminc,
 Can you provide specifics about your tubing ?
I'll probably be ordering my material off the internet  so I need to know a few more details.
 I know you said the jack rails/matix are one inch but they don't look exactly square.    Next, what gauge or thickness ?
Also, how did you mock up the rear section ? Did you use card board as a template ?
My 87 Tbird frame is different than your cougars.  I don't know how I can use a straight piece of tubing since my rear section is off set to the inside.
Last, this goes to everyone.  Please show a pic of the rear section of the brace.  Thats the most complex area.
THANKS TO ALL OF YOU FOR YOUR REPLIES !
Subframe connectors
The subframes should be identicle. Part of damiacs rear quarter panel and rocker is from a 87 t-bird...
Subframe connectors
I don't know about that.
He only used the outer skins on the rear I think.
 If what you say is true where are the rear sections welded ?
Here is a pic of my 87 Turbo Coupe rear section.  Tell me how I'm supposed to get a straight piece of square tube to line up perfect.
Subframe connectors
here is where my frame ended up. correct, it is not in direct line with the front frame
its something like  1-1/2'' off from front to back.
if you want them to connect without hanging down to low, you going to have to cut your floor to get to at least the bottom of the rear frame section.
I cut the bottom of the front frame and slipped my 2x2  inside of it. its welded all along the bottom, all along the top inside the old frame, and all along the floor. I have chucks seat braces also welded into the 2x2
I fabbed some plates to attach the 2x2 to the rear section of frame. Its an L. I cant find the actual picture of what I used, but here was a small piece as an example of what I did, and how much it off from the front.. I dont know if I have a pic of the other side of the 2x2, and the plate on there
here is the 2x2 cut into the floor
here you see the front is notched, and theres a plate on the rear. this took a lot of engineering, and a lot of angles, seeing that the outer jacking rail is higher then the 2x2
good luck
Subframe connectors
Thanks
Subframe connectors
Daminc, thanks for posting those schematics. I think I'm gonna fab up a slight variation of your design for my bird. Willing to bet those will beat the hell outta the Extreme Matrix Brace System by kenny brown, and for not even a quarter of the price!
Subframe connectors
Quote from: 2tbirds;411927
Soul,
 That pic is hot too.  Is that your car ?
 How does one get thick tubing bent like that Rack & Pinion Cross Member ?
Or is this a pre-formed piece ?
Sorry been missing this to reply, GOD NO that is not my car, I wish it was. I don't have a tenth of that guys talent. Check the thread, he also makes his own intake for a 5.4
Subframe connectors
ic is a great fabricator and welder. Those bars are well thought out and assume.
Is that red stuff old fashioned RED LEAD??? looks like it!!!
Subframe connectors
Quote from: TOM Renzo;414485
lol...I hope not... its this
http://www.corroless.com
Subframe connectors
(going back to the mustang posted earlier) I have never understood why a person wouldn't go ahead and run their rails all the way back and tie them into the rear subframe instead of just butting them up against the cut off factory front subframe, and then add in SFC's between the two... running the rails all the way back and completely eliminating the factory front subframe would be sooo much cleaner
86 Mustang GT
Subframe connectors
I agree.... If your going that far...make a real frame for it... I'm planning on trying to do that to my vert
