Topic: O2 sensor harness (Read 1194 times) previous topic - next topic
O2 sensor harness
Yep, they work. Or just extend the wires in the harness for free.
O2 sensor harness
Do you just use the same gauge wire and solder it?
O2 sensor harness
That's what I did. Pulled the harness 9easy stuff), lengthened the wires the appropriate length, soldered them and used heat shrink over that. Added new wire covering material, done.
O2 sensor harness
Okay sweet. It's better than paying 30 dollars.
O2 sensor harness
I need new O2 sensors anyway, so I just bought the ones with the longer wires and plugged them in.  No cuts/no splices.
Mike
O2 sensor harness
Yeah mine are original so I could replace them it's just a matter of time of when they will go bad
O2 sensor harness
What brand O2s do u buy?
O2 sensor harness
I've had good luck with bosche.
