Topic: Torque to Yield??? (Read 3479 times) previous topic - next topic
Torque to Yield???
Well
Torque to Yield???
I don't even believe specific torque values are needed to be exact. I've always assumed that the torque was more to make sure all the bolts were the same so you do not hurt the housings or strip out threads.
I think seek nailed it.
Torque to Yield???
Not
Torque to Yield???
Quote from: TOM Renzo;411282
@JeremiB
Exactly what you said is what i understand is FACT. But check this out. Here is another wrench in the works!!! Studs for example naturally have the pitch and size of the engine they are designed for. But the nut side is normally a fine thread. This makes the clamping load more consistent. So normally they reduce the torque specks on that type of arrangement. You know something we remove and install  bolts and dont really know much about there design and function. I remove Bolts every day from brake calipers to head bolts. But do we really think about them other than what size socket we need to remove them or tighten them up???? Silly but true!! Thanks great discussion!!
I looked at my coworker's fastener books for a bit and got a bit more edumacated.
TTY fasteners are superior (consistency-wise) than studs. Better than torque-then-angle. Here's a chart showing how TTY is not affected nearly the same as fasteners tightened by torque.
In the above chart, if you tightened the fastener to a certain torque, you can see the wide variation of actual preload achieved.
With TTY fasteners, once you get into the plastic area (yield zone), the slope evens out and generally takes care of joint variability.
Quote from: Seek;411285
Why are these 70-100ft/lb bolts so sensitive in the first place? With thick enough surfaces, it shouldn't matter at all if it's +/- 10ft/lbs. I don't think the bolts on our heavy, thick-enough fox body motors are too sensitive to the torque values compared to newer vehicles. Get it in the general vicinity and they last beyond the point where freshening up is needed. Is it due to thinner castings and aluminum being used instead of iron? That should be much more sensitive to torque values.
Pieces clamping down bearings I can see being a little more sensitive to torque. I just don't understand TTY for heads, especially when it appears to do nothing for extending the life of head gaskets or head straightness when poor choices were made elsewhere by the engineers (Subaru notably).
There are 3 main reasons for TTY fasteners: preload consistency, higher clamping strength per a given fastener diameter, or less weight (by substituting a smaller TTY fastener to give equivalent preload to a torque control fastener). I bet Ford chose TTY for their consistency due to the alum/iron combo.
Quote from: Haystack;411345
In almost all cases, close enough is okay for fasteners. Torque control (using a torque wrench) will give you a +/- 30% error wrt clamping force. You tighten all of your timing cover fasteners to 25 ft-lbs, and you may get some at 17 ft-lbs, other up to 32 ft-lbs. That 4% error from your torque wrench doesn’t seem too bad now, does it? ;)
Here's the section about head bolt torquing from the SAE paper Ford's 1982 3.8L V6 (820112).
Quote from: D.L Armstrong and G.F Stirrat
Head bolt torquing involved considerable development, the difficulty being the differential expansion of the aluminum heads and steel bolts, augmented by different clamping loads resulting from two bolt lengths. Variations in bolt thread friction and bolt head to cylinder head contact friction, due to small  part-to-part manufacturing variations, resulted in significant axial bolt load variation for a specific applied bolt torque. The objective was to tighten the bolts with automatic torquing machines to provide an axial load of 10,000 to 12,000 lbs. without initiating yield, which occurs at approximately 13,500 lbs. with the 11 mm bolts used. It had been assumed that steel washers would be required to protect the aluminum head from being scored by the bolt during torquing, however, this added interface contributed to the friction variation. A "UBS" bolt, with a washer-like surface formed into the head, was evaluated and did not mar the head surface even after repeated retorquing. The automatic torquing sequence that was developed consists of:
  • Install UBS head bolts and torque to 72 to 87 Nm to equalize the thread friction and set the gasket.
  • Back the bolts out 2 turns.
  • Retorque the bolts to 72 to 87 Nm.
The production automatic torquing machines have torque sensors and recorders. If a bolt is not torque within the specified range the operator is signaled and the suspect bolt is replaced. If a problem is encountered during hot test, or quality control durability testing, the torque applied to each head bolt on that engine can be obtained from the records. A mattress type head gasket with a solid steel core and stainless steel fire ring was developed to match the requirements of the less rigid aluminum head with its differential bolt expansion.
One very interesting note is they weren't using TTY fasteners at this point! I wonder when they changed over.
Other interesting tidbits:
The 1982 50-state 3.8L had a knock sensor
Initial program testing started in early 1977.
Ford developed a new coolant to deal with corrosion from the aluminum
They modified a 5.0 to operate as a 90 deg V6
The GM 3.8L was benchmarked extensively
They were proud the 3.8L beat the 5.0L in BMEP at all rpm ranges
Torque to Yield???
I re
Torque to Yield???
I question how we've managed to have combustion engines for over a century. Again, I don't see the point. I only come back to the manufacturer saving money somewhere, and that's why the change. I don't think there are too many engines failing on cars, under warranty, that are due to fasteners not being TTY or too much inconsistency across bolts.
1988 Thunderbird Sport
Torque to Yield???
Quote from: TOM Renzo;411396
I remember that procedure as i was doing a tun of those head gaskets. But Fel Pro said it was not necessary with there gaskets. The perma torque gaskets did not take a set. Now back to studs. The Midnighter is fitted with studs as well as my TYPHOON. I am coming to the conclusion that studs are a waste of time. As TTY bolts are the best thing at this point. But ARP tells a different story. They claim there studs are better by a long run. So once again i am getting a HEADACHE!!!
TTY has it's drawbacks. The main one being you should replace them after every use. That's not going to go over well for the hot rod crowd.
Quote from: Seek;411403
Until recently, internal combustion engines didn't care about weight savings, CAFE, use aluminum heads with iron block, etc. All these advances require more forethought for bolted joints. Reducing casting thickness and number of fasteners could very well require TTYs in order to meet reliability requirements.
The Ford case very well could be "saving money" since they added TTY somewhat late in the design process. (The head bolts weren't TTY in the 1982 paper). Maybe they needed the ~20% more clamping force a TTY gets for the same size. An upsize of the head bolt would require re-qualification at a minimum, block/head redesign at worst.
Torque to Yield???
Quote from: JeremyB;411408
I don't think those reasons really have much validity. Aluminum heads have been used for quite awhile now, on both iron and aluminum blocks. Many were plenty reliable. Engine casting weight doesn't mean that much either - using thinner deck castings and smaller bolts really doesn't save that much weight. Most vehicles today weigh hundreds more than cars did 20-30 years ago. It makes sense in vehicles where they try to get the weight down as low as possible (such as my 1800lb Insight) but for everything else, 10-20lbs doesn't do much.
Torque to Yield???
I guess we'll agree to disagree.
Even though the total weight of vehicles has gone up, powertrains have gotten much leaner due to FEA and metallurgy/production improvements. A domestic automotive OEM had LMS Virtual.Lab (multi body dynamics buttstuffysis software) create a module to simulate endless engine combinations (1 cylinder up to 12 cylinders - any bank config, any piston stroke/bore, all variables were available to tinker with) to get harmonics and first order loads so they could feed that info to their stress buttstuffysts to get info for the development of new engines before any metal was bent. MAS Patran showed us a presentation where a domestic OEM used MSC fatigue to redesign a heat exchanger bracket to save a few ounces and change the natural frequency of the bracket to move away from an engine harmonic. Users want safe, fast, and quiet cars. CAFE requires fleet mpg minimums. From what I've seen, OEMs have found powertrain as a way to save precious pounds. Even in 1982, the 3.8L chose aluminum heads purely to save a few pounds. The late model 3.8L Mustang tubular headers? Chosen because for weight loss.
Torque to Yield???
Quote from: JeremyB;411425
Yet even small cars like the Smart Two, Four, etc pass safety standards with their light weight. Why save as little as 10-20lbs in the decks (where the clamping force matters) when the rest of vehicles are overweight? Perhaps the drive train engineers are doing their jobs, but the chassis and ride quality engineers are not. I don't know of many spots that use TTY and the ones that do, I cannot see a little extra weight doing ANYTHING. It's not like they aren't still loading cars up with sound deadening. I again come back to my Insight which has basically none. They seem to want to do nothing well in most cars, rather than excel at some things and fault at others. This is the reason I liked the 1st gen Insight - it was built for economy and excels at that. Other vehicles just have extra weight stuffed everywhere, many of which are in the wrong places.
I'd think that production costs for each part of the vehicle are making the decisions more than anything related to mpg requirements. It just doesn't make sense to me when the problem seems like it'd be solved by adding as little as 0.2% more weight to something that isn't part of the rotating assembly so it really doesn't matter, other than saving small amounts here and there as the manufacturers cut costs, and possibly speed up production in some ways.
Other pieces, I agree can be lighter. Why not? An example is our 80's alternator/smog pump bracket. That thing was over-engineered. Thinning it up would have no drawbacks. Then there are many other areas that could use some weight loss. Then there are others that should NOT have material taken away. An example is the clocking tabs in my Insight's transmission - it prematurely wears, causing the syncros to not function properly. People generally believe this is due to attempts to save every ounce of weight and the material is too thin. Computer software is wrong all the time - better than nothing but the real world often shows different results.
Anyway, what exactly is the useful purpose, other than pennies, of using thinner decks and smaller TTY bolts? Saving 1 gallon of fuel over 100k miles? Decreasing the braking distance by a fraction of a millimeter? It would seem that just the clothing that you wear one day can decide more about the vehicle's weight rather than 1/4" of additional aluminum on two surfaces.
Again, I agree about things like bearing caps where exact torque specifications and rotational mass matter. I'm not one to say otherwise as there is a LOT that goes into moving parts which I will never know, or care to know.
Torque to Yield???
Not many people want a Smart car (1600 lbs). They want bigger, faster, quieter cars like Civics (2600 lbs), Camrys (3200 lbs), Tahoes (5500 lbs). Smart sold 10,000 Fortwos in 2012. Toyota sold 30,000 Yaris's, 300,000 Carollas and 400,000 Camrys last year. OEMs are willing to give them what they want, or be left high and dry. When fuel prices go up enough or CAFE gets sufficiently demanding, cars will shrink and noise abatement will decrease - but until then, the people are generally getting what they want.
How do you eat an elephant? One bite at a time. Same thing with weight reduction. Ounces here and there add up to noticeable savings when you save everywhere you can. Car makers save everywhere they can in the most cost efficient manner possible (with obvious exceptions, you have time/budget limitations and aren't 100% efficient). LMS Virtual.Lab also has an acoustic module that lets you design a car interior and actually hear the effects of different dash/door/carpet/sound deadening materials to the user so they can save weight. I was in a training course with a Dodge engineer whose job it was to minimize the length of A/C hoses to decrease weight. Etc, Etc.
I've got some aquantances I know from Honda R&D I'll see this summer. Will ask them how they are directed design-wise - performance, weight, cost.
Torque to Yield???
Quote from: JeremyB;411461
It would be interesting to do the above. I'm also curious about some of the design decisions. My Insight also shows that they didn't care much about gaining extra interior space. The battery system has one spot where air flow is controlled - the rest is just in a huge open cavity with huge open pockets in the hatch area, under the aluminum sheet metal that they used to enclose everything other than a little cargo area and spare tire well. If what you say is true about them looking to save weight in some areas, it doesn't look like they give a second thought to other areas of the vehicles.
Looking under many hoods, you can easily see places where they could have done much more planning, but I assume it still came down to money or time, more than their desire to simply lose a few pounds. Things that they HAVE done to many vehicles is decrease the weight of the seats, without really losing anything. Then I see other contraptions that manufacturers put together to making seat adjustment easier or add more adjustments, and it adds much of the weight back in. I don't see any standards controlling any of this except the hope to get more buyers, and save some pennies here and there (which can add up to millions).
I'd love to play around with modelling software, but it seems it'd be about as realistic as desktop dyno software. Fun to play with and get in the general ballpark, but the real world has proven to me many times that things that are extremely sound on paper do not play out the same way when put to use. I don't think noise has that much to do with economy or emissions though. Smooth panels under the vehicle, proper placement of sound deadening materials (yes, up to 50lbs total though) around the wheels, and aerodynamics provide a ride that can rival the noise levels of my Tbird (which has wind noise problems...).
I want to know how Honda messed up the hybrid CR-Z so much. It's good at nothing and mediocre and most. Power and fuel economy of regular gasoline vehicles, okay handling, fairly aerodynamic shape but not really aerodynamic, comfort levels are okay. The Civic hybrid is larger and does well in power and better in economy, even with its shape that is further from teardrop. It's about as "sporty" as you can get in a hybrid though. I'd take a Turbocharged 1st gen Insight over it though.
