Topic: Start of the Part-Out - 88 Thunderbird 5.0 (Read 2777 times) previous topic - next topic
Still got the odometer cluster assembly?
Go Fast the first time.  The tickets the same.
86 Thunderbird 5.0.  All original good weather driver. Tbird Reg #53035
86 Thunderbird TC.  All original good weather driver.  Tbird Reg # 58555
87 Thunderbird TC.  All original good weather daily driver.  Tbird Reg # 64647
I do.  Speedo is speed modded (will display to 199), odo reads 187k or something.  I can tell you how to swap the odometer chip, but it takes some balls.
Do you know if I can take just the water gauge out of it?.  My Speedo is fine but my temp gauge doesn't work properly.
No, not for sure,  it appears to start to work as I run the engine, but only goes about 1/3 the way.  I tap on the plastic and it moves a little higher but just doesn't seem to get to the normal range.    If not the gauge any ideas.  Is there a way to test the gauge itself?  I suppose after all this time the thermostat could be out and its just not heating up properly.
Do you have the front and rear side fendert trim? I need some nice pieces. All 4.
What I still have is the manual HVAC box, the moonroof frame and glass, the moonroof motor and overhead console, the visors, the c-pillar interior lamps and switch, the radio, the base digital cluster, the clock, the keyless entry module, right side inner and outer front park/turn lamp housings, the left inner front park/turn lamp housing, leather nose cover and wire wheel covers with tool, caps and mounts. Underlined for quick browsing, will add more to this post if I remember/find anything else.
