Topic: My '88 T-Bird Turbo Coupe (New Paintjob in Progress) (Read 12788 times) previous topic - next topic
Looking Good
looks real good i like the color
Thanks guys. That is an old muscle car color from the late 60's, and will look Dark Green, Dark Grey, or Black depending on lighting and viewing angle. Looks more Dark Grey in the pics because of the fluorescent lighting. Great paint as well, lays like a champ. Should have more progress pics soon, I'm starting on the door jambs tonight.
If Steve McQueen had a thunderbird it would be that color with torque thrusts. Looks good buddy
Quote from: 87thunderbirdBlackJack;414512
My name is Brandon, and I support this post. :)
That's an interesting color. Can't wait to see it all painted. :D
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
You and me both. I'm hoping to be done by August now. Kind of sucks, but there is not much free time to be had for me right now.
Got as far as stripping down both the doors, and then I get waylaid by the GF, then we got hit with a shiznitload more business at work this week. It's not looking good for progress on my projects right now. That's life sometimes though. :)
I think I've finally decided to not clearcoat the car though.
Not a great deal of progress the past few weeks, thanks to work, but I'm making some headway. Engine Bay is fully complete, wiring tuck is done, everything is back together, and after replacing my fuel pump which somehow died during the time while I was painting the engine bay, she's purring like a kitten again. Doors are fully stripped and pulled off, and ready to start prepping for paint. Also taking the time to replace all the old cracked rust-inducing Seam Sealer while I'm in there. It would be foolish to ignore, and just paint over it, and would ensure that the paint job and the doors themselves wouldn't last the long run. Only major rust area in the door jambs was on the bottom of the DS door, underneath the old Seam Sealer. Enjoi the pics!
Thanks for stopping by to check out my Bird Project. Will have pics of the doors/jambs painted next. Stay Tuned. :birdsmily:
Hell yeah! :ford: :roxor:
Quote from: Big B;414874
Are you using a single stage paint then?? Or are you adding a hardener to the base coat??
Nice looking home setup that you'll be painting in. :D
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Just a couple of tips if i may!!!
Your doors are very good but need some work on the fold over. Either blast it or the rust will come through again. Also never use plastic on the car as it makes static conditions and will effect the paint application. Depending on the material it can and will cause FISH EYES!!! Also a clear in my view is something that is always necessary but not mandatory. That is your call. Clear makes the paint job. And finally that failed clear on the car has to go. If you are not versed with a DA it can cause other issues. Taking it down is something that has to be dun correctly or the car will have swirls. Remember a DA causes Heat. Be very careful with using a DA.    Good luck!!
sweet it will be shot in no time
There is a masking plastic but yes, I wouldn't use the plastic sheeting for masking.
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Quote from: 1BadBird;416269
Yep, 2K SS Urethane. This is not a base coat, so there is no clear required.
Thanks, I still need to add a filtered intake fan to the setup, as right now my intake is passive, which causes the exhaust fan to pull unfiltered air from outside bringing dust with it. Once I get that setup correctly, I will be good to paint the entire car in here.
Quote from: 1BadBird;416289
Like always when doing bodywork, it's there to protect the engine bay from all the sanding dust while I work, it gets removed during paint. I never have any static problems when I paint regardless, because I already know to ground the car beforehand. All it takes is a thick chain wrapped around the rear axle housing, and touching the ground. Boom, no more static attraction, no more dust nibs. An old timer here taught me that trick way back when. Works Every Time. :)
