Topic: column to floor shift AOD (Read 1490 times) previous topic - next topic
Been searching some of the swap threads on here . For those who have done this , is it a piece of cake ?  I can get bracket pieces etc  off 5.0L mustang , bird cougar from junk yard ? Also I am going to mount a B&M autoshifter .
I did it to my bird. You have to make sure the following things are right or you are going have problems. Make sure your shift linkage seal is in good shape if not replace it. Make sure your transmission kickdown cable is good if not replace it and while you are under there check your throttle cable. Also if you are going to use a B&M shifter you are going to do some surgery to your console( if you have one) if not prepare to cut a hole in the floor to position it and you are going to need a shift rod and the associated linkage and brackets from a floor shift Tbird, Cougar or a Mustang. Hope this helps.
I did this on my bird.... and it was pure hell (with b&m hammer) and the shifter cable wont let me have park and 1st so I use my parking brake, but I was able to make it look factory
this is what I had ti do to make it the correct height
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
