Topic: O.K.....new issue...or may a continuation... (Read 5266 times) previous topic - next topic
This is how i modify the IAC for proper operation. First break it down then do some fancy grinding on the pins . This will allow the IAC to only allow a certain amount of bypassed air to enter the engine. And in turn will not allow the engine to exceed the cold RPM you set it at. Just another TIP!!
This happens at any temperature.
Tom elaborate on that a bit more. Also about the grinding.
As far the TFI, no, I bought one, but didn't replace it yet since the coil APPEARED to have fixed the issue.
Swap the TFI first, since you have one there, and it's about a 3 minute job, IF you have the teeny little socket. Oreilly carries them i do believe.
If it ain't the TFI, I can send you my Mustang's EEC (89, mass air, AOD car) but, I will need it back pretty soon since I will need it for the other Mustang, but that's a whole other project for a little later on..
Thanks Beau. I may take you up on that.
yeah, I have the hand held socket for it. I also noticed something, my wires to the coil in the plug sem loose...I'm swapping the plug tomorrow as well.
I had a similar issue a few years back. Except mine wouldn't run good. Turning the the key on and off and it would clear up. I changed the  Ignition switch and wired in the speed sensor to the ecu. You have an 88 I don't think you have to do the latter part. One of them cured my problem.
I think Vinny has a new switch i THINK??? But if it is not slaved out that is a given. Ignition switch slaving is a MUST!!! He can check it out by just feeling it and see if it is HOT!!! Or making some funky smells.  WHEEE!!!!
Quote from: vinnietbird;409136
No loose wires Vinny that can be an issue !!!!
TIP !!!!!!!!!
Over the years i have been changing the TFI modules and substituting ALLEN HEAD SCREWS for the stock ones. A quick drive to the hardware store and  thirty five cents does it nicely !!!  Also a 1/4 drive deep Snap On socket does the trick nicely. Or just buy the proper tool. Just some options!!!
When i substitute the screws i put a DAB of red paint on the module to let me know they are ALLEN HEADS!!!
I'll try that as well. I have an extra ignition switch in the tool box drawer.
I have the proper TFI removal tool. That's not an issue as far as swapping it.
Make sure you use good dielectric grease on the new TFI. Some guys say heat sink compound, some say the grease...I say grease as well.
My new Ford TFI came with it.
Dont use dialectic grease use heat transfer grease only!!!!!
I had planned on using the grease that Ford included with the TFI.
Since you have the TFI to put in, swap it and make sure that's all okay. Get a "canned air" can from Staples or wherever, for dusting out a computer, and blow that on the TFI when the issue comes up (don't hold the can upside down so that the propellant comes out icy cold and makes that neat-looking cryogenic mist in the air...don't freeze-shock your TFI when it's red hot!). See if cooling it down helps. My guess is not. Especially if this is a repeatable "fix" where shutting down and restarting takes care of it. It's an open-loop/closed-loop issue, I would argue. I *believe* the ECM reverts to open-loop mode for a given period of time, whether that's 10 seconds, 20 seconds, 2 minutes. It certainly starts out in open-loop when the car is started dead cold. Which would suggest an oxygen sensor issue, whether it is the sensor(s) themselves or connections. Check the O2 harness ground as well as each sensor's own grounds. This is where it would help to know someone with a scan tool that can read the parameters in real time, to see if the O2's are flip-flopping 1-0-1-0....like they should.
I need to re-read up on the EEC-IV strategy because I don't remember, but I there is a method to the madness and the reason you see that temporary improvement is the same reason my Crown Vic would do the same thing on a hot summer day back two years ago when I first installed the ill-purchased aftermarket-cammed bad rod bearing motor it currently has. I think getting a 160 degree thermostat and massive 3-core radiator from RockAuto helped a lot. It idles with only 16" of vacuum because of that cam and thus runs pig rich. Last summer it was okay however, I think it runs just cool enough that the A/F ratio it has to deal with doesn't push it over the edge and cause it to start stumbling. It would frequently backfire lightly through the intake when opening the throttle quickly as well.
Mine has a few instances of backfiring through the throttle. Timing was checked over and over, and it's fine.
The only sensor I haven't changed is the ACT sensor.
