Topic: C clip eliminator installation? (Read 6753 times) previous topic - next topic
Quote from: 50RACER;408568
What did you do on your rear brake set up?
Used ranger 10" x 2.5" drum assembly. Used Aerostar 1" wheel cylinders for some piston area and explorer light weight drums
Kind of a bummer that c-clip eliminators don't work well for cornering. I wanted to run a spool at some point for drifting, but that's not gonna happen without c-clip eliminators. Guess I'll be sticking with the welded 8.8 I put together for this year.
If you want to run a spool for drifting, then buy the 9 inch weld on kit that they have for the 8.8 rears.
Quote from: bryan163;408716
Donnie
10 Second NA TBird
Fredericksburg Va
Quote from: 87 T-BIRD;408717
I was hoping someone would chime in with a solution:D I'm assuming that will require custom length 9" axles to work with the wider turbo coupe rear. My other question is, are the 9" axles compatible with an 8.8 spool?
If you contact an axle company like Strange, Mark Williams or Moser, they can put together everything you need to assemble your setup. If you tell them you want a certain length axle with a 9 inch bearing setup and the 9 inch bearing ends for the 8.8 and a 31 or 33 spline axle and spool to fit an 8.8, they can.
Donnie
10 Second NA TBird
Fredericksburg Va
Good to know! That might be next seasons setup, since this seasons rear is all ready assembled. Might get it installed tonight.
Bryan, you should really look into an axle brace CHE has them for the mustang, I'm sure they have them for our 8.8's Doing the hard stuff to your axle that you do. Ive seen 7.5's and 8.8's blow the tubes right off of it. Its that little bit of extra security. it wraps around the pig and bolts to the bottom of the diff cover and also bolts to where the dogbone dampener is then branches out to the LCA mounts Its a pretty trick setup.
My buddy had a 78 zephyr he was hot rodding it real good after work one day slid it sideways and it bounced because he tromped it and blew the axle tube right out.
That's a pretty shagy piece of hardware. I'd like to get my hands on that girdle cover too.
Its pretty but welding the axle tubes to the center section would pretty much to the same thing if a person thought to do it during a rear end build.  The other part is having access to a welding rig and a welder that know how to do it correctly.  For me that piece would not work with a torque arm so its out of the question.  I think it would even get in the way of a panhard bar and would be a no go with a Watts Link.  Again, someone with these components would most likely have access to a welder and work over the rear end welding the tubes and putting on the nine inch ends.
I cannot stress to you guys enough to not run C-Clip eliminators road racing.  They may work for a duration of time but they will eventually start leaking and most likely when you least need it to happen.  Almost every manufacturer of them will have a disclaimer about street and road racing use.
Darren
I thought  the same thing. I'll just make sure it's straight and weld the tubes when I have it out for the rebuild.
Those look nice and keep everything tucked up nice and tight.  Might even be able to make a torque arm work with them as well.
Darren
Why not just weld the axle tubes to the center section??????????? Been doing this for 40Years. Just saying!
The braces wont prevent tube twisting out of the center section. Tube twisting is a greater issue than most think and a wif of ozone and some sparks from a Miller will suffice quite nicely.
:flame::flame:
