Topic: Valve cover vent tube...... (Read 10563 times) previous topic - next topic
Reply #45
Quote from: Chrome;408338
Just an added note. Any air entering the engine must be filtered, or else unwanted debris will go in as well. Breathers are filters and must be cleaned on occasion.
Correct and with MOLLY RINGS that is a GIVEN!
Reply #46
I have molly rings in the Sport's engine.
Reply #47
So, the tube would work the same if it went to the back of the intake instead of the throttlebody, right?
Reply #48
No, the manifold would be a vacuum source. The tube is meant to reside upstream of the throttle plate where it is only subject to atmospheric pressure.
Reply #49
Vinnie just connect to the air cleaner like I said in the first place
Cap off the throttle body
Reply #50
My air cleaner is a MAC CAI and I don't want to drill into it.
Reply #51
You can avoid drilling your intake by using a separate breather filter. They sell some at Advance that are the right size for your breather tube. They also make filtered catch cans, so if you get blowby you can catch the oil. Those you can get in Jegs or on eBay.
Reply #52
The new valve covers don't have a filler tube...or any holes at all yet.. I'm using them so they'll be different, but I have to address the oil fill and tube.
Reply #53
I didn't know we were talking about retrofit
This is the first I've heard of it
Reply #54
O.K., I thought I mentioned that. Apparently not....now, I'm installing valve covers that have no holes in them at all except for the bolts. I am trying to keep the look as clean as possible, while having an oil fill and the vent tube.
Now we're up to speed. LOL.
Reply #55
I'm over thinking this perhaps....If I install a breather, The tube doesn't need to be there anymore....because the breather, in effect, does that job now.
Right?
Reply #56
OK simple you need a place to put in oil!!!! That place is the valve cover. So a breather is necessary on one pick the side. With that if you get lucky it wont PUKE out oil like brian so correctly said. So a baffle just might be necessary in my experience and a hole has to be drilled in the cover for a fill port and vent. Thanks
Reply #57
Vinnie post a couple of photos of your engine with the original setup and valve covers and the tube. That would be very helpful so we can see what you are trying to do. thanks
Reply #58
It looks like a stock 5.0 setup, but with finned aluminum covers. I have baffles for these covers, I just haven't drilled any holes yet.
Reply #59
Ok then what is the issue at hand??
