Topic: High beam with low beam mod with an easy jumper wire (Read 7551 times) previous topic - next topic
Update:
Mod still going strong.  For the first time in my adult life i can finally say that i am bothering other drivers with my high beams  :P
its about time!!!!!!!!!!!!!!!!
still going
with a thermal couple taped to the headlamp rear while moving the temps on the housing reduce about 60%.
the thermal couple was being held down by tape so windage effects should have been to a minimum and should have shown an accurate heat situation.
im rather pleased and still dominating the roads with bright light.
still going strong, no adverse effects can be detected, lamp contacts are still clean, housing in tact,,,, i consider this test complete and the existing wiring capable of doing the job.
