Topic: Post products you are **EXCEPTIONALLY happy with (Read 25829 times) previous topic - next topic
Reply #61
Lowe's currently has a 3/8" drive, 19 piece ratchet and socket set on sale for $19.98
https://m.lowes.com/pd/Kobalt-19-Piece-Standard-SAE-Mechanic-s-Tool-Set/3364144
The very same ratchet by itself is normally 5 bux more...
https://m.lowes.com/pd/Kobalt-3-8-in-Drive-Quick-Release-Ratchet/3381168
It's a 72 tooth.  Buy the kit, tear the ratchet down, and lube the gears with automotive grease instead of the BS penetrating oil that's in there.  It's now smoother than silk.  I picked up a 1/2" and 1/4" as well.  My old Craftsman ratchets had seen better days and they were 36 tooth.  A pain in tight quarters...
Reply #62
I stumbled across this thread and thought I'd add to your list.
Check the link below.
http://www.archoil.com/
I've been using their AR9100 Friction Modifier and AR6200 Fuel Modifier for a number of years in all my vehicles and the AR6400 in the TC and Prerunner.
If you own a Ford with a 6.0 like me you have to try it. It's a necessity. With all of the money you have invested in the motors, trans, rear ends in your cars you'll want to check it out.
Just read the reviews.
Over the last few decades I've probably tried most of the oil and fuel additives on the market, most with dismal results and wasted money.
The results with Archoil are immediate especially in the 6.0. I'm not a salesman just want to share information about a product that works.
I use both products in my 87 TC, 2005 F350, and 2004 Tacoma Prerunner. I run Mobil 1 in the TC and Prerunner and T5 in the 350.
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
Reply #63
updated post 1 with ways to kill puppiesanese beetles and potato bugs
Reply #64
updated post 1 for a new kind of matress all of you should know about!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
and its not expensive ,,,, and they ship them in a small box!!!!!!!!!!!!!!!!!
