Topic: Needing a transmission bad (Read 1726 times) previous topic - next topic
A good friend of mine is in need of a transmission for his 1995 mustang cobra it has a five speed. also a good rebuild kit for one would work as well.
On craigslist, in Kansas City, there's a guy who rebuilds T5s, I am sure the '95 Cobra used something else, but he may be worth a call at least. Just type in T5 in the KC section...should see his ad smoewhere in there
Yea I got a buddy here in ca that dose them
A lot of people do
The sn95's had the longer input shaft and bellhousing. I've heard you can use either one, but match them. Its about 3/4" further back on 94-95 5.0 and 94-04 v-6's.
My friend has the T-5. Fox bell housing, slutch set, cable, and everything else for it except the pedals. $600 shipped for everything.
I just installed one. The 95 cobra r is the rarest of the t-5s yes it works yes you need a different bellhousing and no a standard t-5 rebuild kit will not work. The 95 is good for around 600hp and is a great trans. I did have to trim the opening in the tunnel for the shifter( mine was auto). Also the input shafts are different 28 spline instead of 10
The '95 Cobra R did not come with a T5.
It was a tremec in a 95 cobra t-5 based but holds much more power/torque.
It is a 3550 tremec. Great trans
