Topic: would anybody be willing? (Read 1940 times) previous topic - next topic
would anybody be willing to do up an buttstuffog cluster for me?. im looking for a 140mph speedo and 7k tack for a v8 car. i currently have my cluster from the sport. i was going to convert the turbo coupe cluster i had but i ended up throwing it out. if i need to get another one i can. i realy only wanted to do the tach so it matches the speedo so it could be the standard one i allready have, just printed up to match the speedo.
apparently im not patient, outgoing or good enough with electronics to pull it off. ill pay you for your time as well as parts. just wanted to see if anyone would be willing. thanks guys...john
~John~
Re: would anybody be willing?
:giggle: guess not... :rollin:
~John~
I've thought about making an entire buttstuffogue cluster for swappers, but I'm still currently working on finding a good voltmeter to replace the py, pretty-much nonfunctional amp guage for all those non sport and tc owners.  When finished it would look all stock, like it belonged there.  My own current cluster came from a sport and has one of our custom 140 speedos, and the solid-state ivr mod found on tccoa.  I also had to rewire the check engine light b/c I swapped out the standard dummy light config from the sport cluster for a tc one, so that I could obtain the never-used "upshift" light, for when I plan to install an rpm switch.  I hooked up the factory alt dummy light wires to the "antilock" light...eventually I'll cut and paste in a battery lense, so that non sport and tc converters can still have a functional alt dummy light, as well as a decent volt gauge.
Quote from: joefriday
 Joe, I did the same thing on the my Blue base bird that has a Sport cluster.
My old '88 Aerostar actually has real gages(not the bi-metal POS), that I could live with in my Tbird. To bad they are on the oppsite sides, so I doubt they would be adaptable...
