Topic: Timing a possessed Cougar. (Read 18755 times) previous topic - next topic
Reply #180
Yes we were LETHAL ALL RIGHT TET 1968.
Been their on the lethal GAS ISSUE!!!! WHEEEEEEEEEEEEEEEEEE SEA RATIONS!!!!! YUCKIE!!!! Thanks Guys!!!
Reply #181
mr 86 here is a retired Raytheon guy,,,,!!! im sure our service has crossed paths more than once or twice directly or indirectly.
Reply #182
It's been my pleasure learning from you guys! Some times it's like going to the Smithsonian Institute of cars and asking about a fuse link. (lol) Jcassity, It was a pleasure talking to you the other day, hopefully I will get the chance to talk to some of you others as well. I'm beginning to think NASA should start building fuse links. If they can make a doll that talks, they can make a fuse link that will tell us why it blew.
Reply #183
You don't need NASA to do this. If you have a small 0,5W light bulb all you have to do is to wire it across the fuse link. If it blows, the bulb will shine.
Reply #184
So, if you hook up an LED beside your fuse links, and your car blows one on the road at 1:00 a.m., you could easily diagnose the problem.
Reply #185
Well if you loose a link at 1 am you are screwed even if you know which one it is D'OH!!!!!
Reply #186
Quote from: 86cougar;403601
Cars do not use them any more. They use MAXI FUSES and you will most likely know in 30 Seconds when one BLOWS
STUFF STOPS WORKING  D"OH!!! :toilet::evilgrin::shakeass:
Reply #187
Quote from: TOM Renzo;403615
Yes, (wanna be) HEAD ROOSTER, we know.  Do you read english? You seem to miss the point a lot.
Reply #188
REALLY man now i am disappointed in you. You dont like my postings or advice OK will bow out. I know when i am second best. Thanks for the warning
NOW I AM A WANNER BE. OK that is cool . BUT!!! WANNER BE WHAT> like a mechanic. Just a thought.  What point am i MISSING. Fascinating several times i pointed out troubling shooting procedures to you that you missed the point on. No sweat i will be good from now on Thanks for the beat down i like when that happens. Have a good weekend!!!
Well here is a simple project i am working on. Re pinning an ECM from OPTI spark LT1 to LS COP. I am confused but i will mill through it.
OK FINISHED> NEXT wiring issue. Thank god Thomas Edison Stopped by. I would have been lost without him!!!
http://www.youtube.com/watch?v=-LCsiWL6gn0
Reply #189
I think the point your missing is that there is not a HEAD ROOSTER on any forum. You seem to get real upset if someone else voices their experience or advice. It doesn't make you wrong or them right. From what I've seen and heard here you are most likely a very good mechanic, but your only one of MANY on this forum. Good luck on you nest.
Reply #190
Quote from: Trinom;403608
kinda like  pilot fuse for a larger fuse such as what they we do with larger fuse panels in -48v dc plant,,, like with an 800A TPL fuse in that using a pilot is the indication which fuse blew.
decent idea really.
Reply #191
Quote from: TOM Renzo;403614
had this happen to my son, on the road.  jumpered around the link with his power window circuit breaker knowing it was a risk but with the safeguard that the breaker would open if there was a real downstream fault... there was because the breaker opened so we pulled him home.
Reply #192
Safety first. Nobody want to force a bad issue with their car and maybe make matters worse. But, it would be nice to know where the problem is. Diagnosing a electrical problem can take some time and be a real pain.
Reply #193
DAM and i so wanted to answer this!!!!!!!! Hay how about FOG HORN. Did you like the clips. Nobody listens to him EITHER~~~
