Topic: Driveshaft length & compatibility (Read 5721 times) previous topic - next topic
Hi guys, I have a problem. Boys from the shop, where I have my birds, lost the driveshaft from my red bird, so we're looking for a replacement.
We've found this:
- Driveshaft for the C3 transmission is the same length, as for the AOD.
- I wasn't able to measure the length of the driveshaft on my silver bird with manual, because of the catalytic converter.
- SN95 Mustang has shorter driveshaft and the output shaft on the tranny has bigger diameter.
- Distance between rear axle and the transmission on my car is 142 cm (55,9").
- Transmission output shaft diameter is 27,2 mm (1,07").
There is one MN12 Cougar on a salvage yard 250 miles away (but the owner is my good friend), so what about this? Can it be used? Or what car should I be looking for?
Why not find a CrownVic PI and have it shortend
87 TC
How does a drive shaft get lost?
I don't know, but they lost it. They mistakenly traded it with transmission parts for firefighter's Suburban (which is unfortunatelly sped already :()
Is there any better idea than shortening Crown Vic's DS? It's incredibly expensive here.
48" for a 5 speeder. I never owned an auto so you are on your own. Or have a new one made. They are not that expensive!!
here's my crazy drawing.... lol
I used the same drive shaft from the AOD to the 5 speed.
I have a spare driveshaft in the garage (using an aluminum one now), but would imagine the cost of shipping would be crazy high.
Thunderbird or Cougar would be your only options unless you find another one to shorten, like a Crown Vic.. And even then, you'd still need the correct yoke and  for it.
If the shop lost it, let them figure it out and make it right. It shouldn't be your responsibility. They gave it away.
Jerry, you do beautiful work.
Kitz asked me a few years ago, so I sent this to him
I'm pretty sure the DS size itself is measured end to end not on center with the U-joint...Its close enough...some people have mentioned that theirs was an inch longer then mine.. from a 5.0... don't know if it matters
Quote from: vinnietbird;402105
lol...looks like I might have had a couple beers when I did this
Thanks guys, We will try to use the DS from my silver bird with manual transmission. I need the red one running, the silver one can stay there the whole winter.
Mine at my shop on the floor, I'll get some measurements. I'm heading there now.
The driveshaft I had in my Bird overall length was 57 inches, the measurement from center of ujoint to center of ujoint was 49 1/8 inches. The driveshaft is out of a 1987 5.0L AOD.
Donnie
10 Second NA TBird
Fredericksburg Va
Quote from: 87 T-BIRD;402273
yep...the DS itself about an inch diff then the 3.8s... I remember having everyone measure theirs because mine was diff for some reason
