Topic: Using a manual transmission with handcontrols (Read 24356 times) previous topic - next topic
Reply #75
I thought about the "travel" issue after my last post.
So, no matter what I do with the combination of M/C and S/C, in order to keep the same clutch movement and pedal movement, the force to press the clutch will be the same?
I diffinently need a power adder!
Reply #76
Quote from: thundergrowl
Yup... You are gonna need a vac or hydraulic booster of some type..
New Idea
Reply #77
I got a "somewhat" new idea last night. I'm no masterblaster when it comes to diagrams but see the attached.
  • Remove the hydraulic line at the slave and extended it to a 2nd slave.
  • Used the 2nd slave to push in the brake master cylinder.
  • Tee together the two brake lines from the master and take them back to the slave on the clutch.
  • An electric vacuum pump supplies vacuum to the booster.
When I'm driving the car, I turn on the vacuum pump and have a power assisted clutch so I can use the hand clutch. When an Able Body (AB) wants to drive the car, power off the vacuum pump and they will have a "normal" clutch.
There are a couple small problems/unknowns that I may have to experiment with like; are the slave and brake master a 1:1 relationship or will I have to put some kind of lever system between them; how much vacuum will the pump have to pull to get the required force on the clutch lever.
EDIT: could I hook up another clutch master to the booster and disgard the brake master? If I could then I wouldn't have to worry about ratios
Reply #78
I picked up a slave cylinder this morning. $62 for it new. If I don't go snowmobiling this weekend, and it looks like I won't since the forecast is calling for +8 and rain for Saturday, I'll get the slave connected to the brake master.
Reply #79
why would you need an electric vacum pump? why not just tap onto another one? dont the t/c's have the same setup for vacum?
Reply #80
Quote from: Haystack
The idea for the electric vacuum pump is so I have control over the vacuum. I can adjust the vacuum pressure by adjusting the voltage to the pump to give a lighter or heavier clutch feal or I could turn it off when someone who has the use of their legs wants to drive the car.
I probably will use the vacuum from the cruise control for testing purposes.
Reply #81
Don't forget that shifting under boost could be a problem without a pump, too - even if you have a reservoir you'd probably use up the reserve with one or two applications.
Reply #82
I tackled the handcontrols again last night and made a couple small tweeks. I adjusted a couple levers and pivot points, I hooked up the trottle cable, and connected the clutch cable.
With that done I managed to pull the clutch lever with one hand, start the car and moved it forward about a foot using the handcontrols. I know that's not a BIG accomplishment, but it was the first time I moved the car.
These handcontrols will work but it will take a little more trial and error and a little bit more money...but IT WILL WORK. :) Then I'll focus on the power assist.
Reply #83
That is awsome dude!  It is a BIG accomplishment!
Reply #84
Thanks Claude!
Here are a couple pictures of the handcontrols as they are right now.
The clutch cable is connected by the bolt on the right, the lever pivots on the bolt to the left and the rod is connected to the clutch pedal through 2 snowmobile tierod ends.
Here is tha master cylinder and clutch slave I'm going to be using for the power assist.
Reply #85
Dude, i have to give you major props.
Im downright sick of people who are disabled bitching and complaining about "i cant do this", "i cant do that", when it takes a little extra effort.
You have my respect for taking it into your own hands, and doing something about it.
Reply #86
Quote from: Tbird232ci
I do that a lot :rollin: :rollin:
Thanks!
EDIT: About 10 years ago I came up with this idea...
That idea was born out of frustration trying to get the stepson to clear the driveway. I got an award for that...along with building a fence around the backyard and chopping my own firewood. Actually, that award was for the positive image I was conveying to my neighbours. One of my neighbours was so impressed he contacted the CPA.
Reply #87
That's awesome, my hat is off to you.
:headbang:
and to think sometimes I wanna give up on an idea because of my ankle, or at least put it off for a while...
Reply #88
Hmm, I see.  If you move the fulcrum(sp?) you will gain mechanical advatage  but you will have about twice the needed travel of the cable.
Reply #89
Quote from: CougarSE
That's right! There is 1" of travel on the cable and the pedal needs to go down 6". The clutch lever moves 3" so the overall effect is I have to pull twice the force with my hand than I would have to use to push in the pedal. 45lb through 6" for the pedal and 90lb through 3" for the lever. Taking into account any losses in the lever system, such as friction and bending, means that the number is closer to 100lb.
I picked up a flaring tool last night to start on the hydraulic lines. All I need now is some fittings, tubing, and a tube bender.
The next step is to connect the three lines together from the brake master cylinder and connect them to the slave. Then I will see how far I will have to push in the master plunger to get the slave to move through it's full travel of 0.5".
With that information I can figure out any leverage mechinism that may be needed to connect the first slave to the brake master. I wouldn't be luck enough for it to be a 1:1 relation :( What I mean by that is full travel on the master will result in full travel on the slave.
