Topic: bumpercover (Read 1137 times) previous topic - next topic
bumpercover
looking for a tc front bumpercover to fit my 85 tbird.also want caster/camber plates for same. will by or trade.
have complete 88 tc rear end[3:73,posi,discs]to trade
also have have 70[73]mm ford maf housing to trade
or what do you need? might be able to get it.
prefer that you call,collect if need be.(270)826-7375.
i live in the western ky area.can deliver part way,possibly.
Re: bumpercover
I have a blue one off of an 87 turbo coupe but i think two of the little slit type things of the bottom are broke. It would be an easy fix though. It will need to be repainted. I imagine shipping would be a pain as I'm in westeren pa. If you would still want it i'll trade it for the maf housing. Will the maf housing work without any modifications?
Re: bumpercover
i need a cover from an 83 to an 85. cougar or tbird.the one with the factory chin spoiler and driving light openings.
as far as the housing goes,got mine(and a couple extras)from the junkyard.they came off of 94 0r 95 cougar/tbirds with the 4.6. had to reuse the 55mm maf sensor because it was calibrated for my injectors.
i tried the sensor that came on the 70mm,but the engine didnt want to idle.i raised the idle speed and readjusted my tps sensor to get it to idle,but it would try to die when i would put it in gear.so i said the heck with that and changed to the 55mm sensor and the 70mm housing and set the idle back down and readjusted the tps sensor to .98.everything is fine now.
