Topic: My newly aquired 88 Thunderbird V6 (Read 13693 times) previous topic - next topic
Quote from: 50tbrd88;400054
Your car is very low! I had a heck of a time with sing tailpipes with those springs.  Glad they worked out for you!
It handles so much better now!
thanks again
X-Mas Came Early!!!!
In total I have a 1993 SC engine, 2 Superchargers (1 w/ underdrive pulley, 1 stock pulley), 2 sets of piping, 1 intercooler, flywheel, 1 AODE SC trans, All included wiring harnesses, 1 SC computer (chipped), stock shifter, 1 alternator, 1 starter, all belts and pulleys, 1 SC gauge cluster, 1 wiring diagram and I even got it delivered!!
Yes this is the Bird i am working toward basing the drivetrain part of my build on... the 1 of 15 1988 Ford Thunderbird LX police prototypes w/ super coupe drivetrains
They should have done this and not switched the bird up till 93' like the mustangs.
glad to see you got the engine, i figured i get a picture in the middle of the night when you got it! lol.
cant wait to start the conversion!
Brian J Larkin
1988 Tbird Turbo Coupe
1989 Cougar XR7
1995  Ranger Splash
I love the cars look, awesome lowered. I really like the basic wheels, nothing flashy but they go well with the silver car. The small white wall looks great too. Man you should keep the v6 in it and just daily it! Worry free, simple, good looking cruiser.
302 H.O Swapped.. Bolt ons.. Tremec 3550.. 4.10's.. 18's..
I do think the 3.8 supercharged is a pretty cool idea though. Never seen that done before, will be unique for sure
Quote from: FirstBird;400491
I agree.. Although they would not be so rare to see if they did. Makes our cars more special
Update
Update:
Parts need MOUR parts....
Mark VII 5 lug Posi 8.8 is on its way
(2) 15" steelies to throw on with wider tires!
(1) CYB-B200E460N Voltmeter
Cyberdyne Gauges Digital Prism Gauges
(1)CYB-B217E461Y Boost Guage
(1)CYB-B220E460N Water Temp
(1)CYB-B221E461N Trans Temp
(1)CYB- B210E460Y Oil Pressure
(1)CYB-B224E461N Air Temp
(1) Black Digital Tachometer & Green LED Shift Light
Item Number: GS-DTGB
My gauge setup will be a secret until i start the bezel but it is something I've always wanted to do.
What master cylinder do i need in order to run my new rear w/ disc brakes?
Started my Dash Mods!
Reply #39
Finally installed my new tach/shiftlight and modified my radio location. The top two dash areas will have 3 gauges per row.
Reply #40
how much are the fronts cut?
88 tbird lx 5.0 ho t5 swap
04 dsg gt
Reply #41
unsure exactly, they were on when i got the car, if i ever convert to air suspension i will measure the old springs.
Reply #42
That thing is in the weeds lol
Looks good
Reply #43
I am looking forward to new mods on my bird!
BJL is hooking me up with Turbo coupe Spindles and a Camber kit
Im sticking with the Linc. Mark VII themed rear setup and going with Mark VII 5 Lug rotors and reman calipers. Also possibly running 88+ LSC 16in wheels with low profile tires and welding 4 wheels in 2 final custom wide rear wheels to run a 255/50ZR16. Ill be installing a Mark VII 8.8 soon with discs and possibly a 3.55 ring and pinion to complement my 93 Supercoupe SC 3.8L engine and trans swap!!
Reply #44
XX
More pics of my bird, currently looking into bagging it, its still too high
