Topic: How do these tie together? (Read 4693 times) previous topic - next topic
Yup, the blower motor draws a good deal of juice.
hmm,, mine does not, although I have the relay mods and No-oxide on all my connectors
none of my power is going through the ignition switch or headlamp switch... steady rock solid
Mine will show 5 bars on my digi dash with no accessories.  Turning on the blower will drop it to 4.
Quote from: mcb82gt;444888
Thank you for posting an actual update, wish more did.
I was wondering if this cluster needs better grounds.  Whenever I switch on the HVAC fan, my Volt gauge drops a bar instantly.  Does your guys do this??
Quote from: V8Demon;444948
Hmm mine does not do this. If I turn the blower or A/C on the same 5 bars are illuminated. Now if I turn the headlights and blower on it goes down to 4. Either I have really good grounds or my voltage gauge is a liar. Probably the later one.
Blower and lights is 4 here as well.  No idea.  My grounds are all beefed up as of a few months ago....
