Topic: Cam and firing order (Read 4615 times) previous topic - next topic
I had an explorer cam sitting around, too.  I chucked it out in s last week or week before. There are lots of HO cams floating around the board, run one of those, you should get a decent power bump.
If you put an HO cam in an explorer 5.0 with GT40 heads, you'll NEED to upgrade the valve springs.
Quote from: TheFoeYouKnow;397660
Ah well, that is usually how these things work out isn't it. :rolleyes:
Quote from: ThunderbirdSport302;397661
That's not going to be an issue, as we plan on replacing the cam with a stock cam anyway.  He is beyond the age, according to him, when souping up a car or truck trips his trigger.  He is doing good, as it is, to keep her between the ditches. :hick:
From what I have been reading, the Ford part number that I am looking for is F4TE-6250-BA and has the following for specs:
1996-2001 Explorer (F4TE-6250-BA)
256 / 266
186 / 197
0.422 / 0.448
116
Here are a few others worth mentioning if someone is looking to upgrade:
1989-1995 Mustang (E8ZE-6250-CA / F1ZE-6250-AA)
276 / 266
214 / 210
0.444 / 0.444
115
1993-1995 Cobra (F3ZE-6250-CA)
270 / 270
212 / 212
0.451 / 0.451
118
Keep in mind the Cobra had 1.7:1 ratio rockers as opposed to the 1.6 on the others shown above....
One of the easiest ways to check for a stretched or improperly installed timing chain is to take a compression test!!!
Quote from: TOM Renzo;397752
Yep, I am gonna do that too. Thanks for the reminder Tom.
My 1977 two cylinder Gravely tractor has a "waste spark" system but I never heard that term before. It has two high voltage wires, one from each end of the secondary coil. There is no connection to ground at the coil end for the secondary coil. The plugs are in series. Disconnect one plug and neither will fire.
Does anyone know where the ford part number for a cam is located?  The reason that I asked is that Dad doesn't want to pull the cam completely out just to check the part number, unless there is simply no other way.  Since this whole thing started he has spent over $700 in gasket sets alone.
Thanks!
All the ones I have seen are...stamped on the back of the cam.  Sorry for the bad news.
Darren
Doh
