Topic: New Here 83 Thunderbird (Read 71883 times) previous topic - next topic
Reply #90
No, local car here in pensacola, my buddy drove it during high school.
Reply #91
A friend brought me some electric fans by, from what I can tell by part number there off a Ford transit connect van, no fan module box but they do work when wired up.  Trimmed the shroud a bit and there on.
X
Reply #92
Similar to a contour should work good
Reply #93
bad pic
X
Reply #94
Wow that's bulky lol
Hard to tell but how well dose it clear
Reply #95
Better picture, yes little bulky, but Freebees!!!  and I did not modify anything but the fan shroud to fit, so if I want slim ones later, no problem!!  I research, and they flow like 3600 cfm!!  I am spaced off core support about 1/2in, so I still have some room.
X
Reply #96
might be hard to tell, but I heated and modified the heater tube to fit around the electric choke since I am using a factory intake for now, I have an extra straight heater tube for later when I get an aluminum intake, which it should clean then.  I did not want to get long heater hoses, I like the idea of the heater tube.
X
Reply #97
Better picture of heater tube, I cleaned up and painted
X
X
Reply #98
Man a plate for the throttle cable bracket and msd  blaster coil.
X
Reply #100
I ran some fuel line and put new power steering lines on, going to try another start this week, and check timing.
Reply #101
Good stuff you know it fires
Reply #102
Going to put a tach in the center, 2in gauges and 3-3/8in tach, equus brand, going to give them a shot!!!
X
Reply #103
Finished fuel line and gauge to carb
X
Reply #104
Not to be a kill-joy since I love what you are doing. BUT I see some bends in rubber hoses that are too tight and are asking to kink down and choke off the fuel and the breather.
Give it another look.
