Protecting your blower motor switch (non-EATC)
Reply #24 –
Slave relays are used to control high current applications. Most every switch in early fords suffered this dilemma. That is why so many of them found their way to the JUNK YARD as they burned to the ground. Over the years i have slaved out the headlights the fog lights the MFS. the blower motor and absolutely the IGNITION SWITCH. The stock wiring is heavy enough to handle the loads. But the switches are not as good and they get hot and melt. Not only the device the plug also. I have checked current flow through the ignition switch and it can exceed 50 AMPS. Basically just about all the heavy current draw switches have to be slaved. This is a pain to someone that lacks electrical knowledge. But never the less it has to be dun. Sooner or later the switches will melt. Slave relays can handle the loads quite well and are very common today on modern cars. learn how to wire them and you will be saving your ride from a possible melt down.
Fog light plug. Burnt pretty bad. I see so many of these .
All connections must be crimpedand soldered for a good connection. Below is a low high beam relay mod!!
