Topic: Protecting your blower motor switch (non-EATC) (Read 10292 times) previous topic - next topic
Here's a little tip for those of us without EATC: we all know that the connector to the fan switch is pr0ne to melting. Ford actually redesigned it a few years later to run the current through a relay when the fan is switched to Hi. A few years ago I rewired it using my 1997 Explorer EVTM as a guide, and hopefully the connector won't ever melt again. It's a pretty easy project for anyone who is interested.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Do you have details to share?  This sounds like a worthwhile project to undertake, especially if you are already in the dash doing something like replacing a heater core or something else of that nature.
yeah, ill put it up on my photo bucket link with your credits within the evtm bundle.
Well, I don't have a scanner, but I do have a digital camera:
The diagram doesn't specify what kind of relay, but I used a 50A one just in case. Explorers use two sizes of relays, big square ones and ones that are half that size. This is the larger kind. They come in different amp ratings, so be careful which one you use. I also used a relay block from a 1995-ish Taurus for mounting the relay, but that might have been more trouble than it was worth since I had to replace all the wires with heavier-gauge ones. I went that route to avoid any chance of short-circuits between relay terminals. There are aftermarket mounting blocks for single relays which is what I would use if I had to do it again.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Awesome, Thank you!
This should do fine, not sure if this is what you ended up with or not but i cant see over complicating it.
Notice the R&R of the original fuse to 5A (approx).
You can intercept the existing DB/LG wire for the relay then apply ground & power as shown.
Thanks jcassity, that is terrific!
let it cyclel through here a couple days, several eyes on things are better than one set.
Im now working on headlamp relays while jacking with this amp guage converting it by using a volt meter.  digikey has a few.
I don't see how that protects the blower motor switch...it protects the multifunction switch (which is a mod I hadn't considered), but it still routes all the current through the blower motor switch when set to Hi.
Apologies if I hadn't been clear about which switch I was protecting. It looks like we have two good mods here.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
ok, you missed calling out which one you were protecting.  Will fix now.
I think your mod is also valid, maybe they should be combined?
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Quote from: Quietleaf;395817
Agreed.  Jcassity's mod protects the function contol switch, which isn't a bad thing, as it is the hot side to the blower.  Quietleaf wants to protect the blower speed switch, which we know melts the connector because that black-out "hi-speed" is carrying the full current load on the ground side, which would require that dual-relay gimmick to switch the ground, correct?
i just about broke my head trying to figure this out without as you called it a dual slave of a slave relay.
I think i nailed it,,, circuit is de-energized now on paper.
Add power to the upstream relay and power is also applied to the lower downstream relay coil and common contact after the motor.
**when high speed is selected the lower relay coil gets an open ground but the power for the motor is now able to see ground from the contacts.
this just might fly,, any thoughts?
Hmm. That doesn't look quite right. I believe this is what I had to do:
Edit: scratch that. Mine isn't right either...
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Got it. Now I remember: I had to put the relay after the Hi output:
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
