Topic: Parts that fail!!! (Read 1232 times) previous topic - next topic
Parts that fail!!!
Well as i rebuild the midnighter i found an issue. One of the HLA lifters failed big time!! But with a cam in the 550-600 lift range i am not surprised. Here is what happened. The top broke off and this is sort of common on a HP 2.3. I have no idea why this happens to date. As the plunger does not ride that high??? Very frustrating. Also this is a standard body lifter!!
As you can see the body was modified by me so a performance cam could be used by shimming the lifter. I started doing this before the lifters were even available. Below is the MOD!!
Parts that fail!!!
valve float? lifter having issues following the cam profile? dono either.
Parts that fail!!!
The Midnighter has hefty springs. But that could be an issue!!
