Topic: Finding An Aluminum Driveshaft (Read 15299 times) previous topic - next topic
Hmmmmmmm, I've got both  :evilgrin: and with 4:30's  :evilgrin::evilgrin:
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
I got lucky when I found mine. I was getting parts for my daughters car and there was a police crown vic next to it. I started looking at it and laying in the trunk was the driveshaft. It even has police stamped on it. I still have to get it shortend and balanced and get it on there. Probably next year when I get the rearend rebuilt.
My Crown Vic driveshaft is 4 inches in diameter.
Just remember, the larger OD drive shaft may have interference problems with other things under the car especially if it is lowered.  I have the FRPP aluminum DS in my Coupe and it rubs on the ebrake cables under hard cornering and acceleration.  I am pretty sure a 4" will be fine in most cases but its something to think about and pretty easy to mock up on and existing DS.
Darren
That's strange Vinnie.  The driveshaft I took out of a Crown Vic is only 3.5" in diameter.  You sure you're not overestimating how big your shaft is?
William
:rollin::rollin::rollin::rollin:
'Vic shafts are 3.5"....don't worry Vinnie, my shaft isn't any bigger around than yours is :P
(Although mine is uncut, so It's got a few inches on ya)
So...you guys that have custom....shafts....
Do you like to lay under your cars and polish your shafts occasionally? lmao
Quote from: ThunderbirdSport302;395191
OMG!!!!  Dude's got an Ardvark!!!!
William
My driveshaft would've rubbed the lers, but I was swapping them anyway, so, no big deal. It was an item to watch for. I have the stainless dynomax lers installed away from the shaft.
Reply #39
Quote from: 88 Blackbird 5.0;395173
:popcorn::popcorn:
Reply #40
I don't think I'm overestimating it's size....I think you're underestimating it's size. LOL. LOL.
Reply #41
Does your shaft flare out at the ends, or is it pretty much the same diameter down its whole length?
William
Reply #42
Same all the way.
Reply #43
I'll measure it in the morning again to double check. I'll report in after that.
Reply #44
Good.  That's the one you want then.  If it's straight all the way, it's a 4" shaft.
William
