Topic: Any body know where to get this? (Read 2600 times) previous topic - next topic
The exterior door window weather srtipping? Also looking for the full door seal. also the upper window seal. I'm looking for new pieces. Anyone know of an after market supplier? I'm getting tired to the marks that the outter seal is making on the windows.
Re: Any body know where to get this?
I've seen the rubber door seals on e-bay, but they are very expensive. I have the rubber seal for pasenger side that goes on the body to seal the door for sale and it's in perfect condition. New can't be any better. Also have all of the trim to go around the window for the 88 if I can get it off (driver and passenger). I'm sure they are in great condition also. PM me if you are interested and I will get pictures. Help me figure out how to get everything off without damaging it and I will set you up a good deal. I haven't attempted to get them off yet (the rubber seal is off but not the other trim pieces). I got a good deal from you before so I owe you one...
Dave
yes i'm interested. Ass far as the outter window trim you have to pry up the metal piece but there are 2 screws holding it on the door. 1 is at the rear of the door and the other is near the front of the door. Any how thoste pics would ne nice. Just let me know.
jc whitney sells em, probley try for mark7 stuff at the dealer to, sence marks stoped production later on theirs better chances of them haveing em.
Alright, sorry to tease, but the rubber seal had a small tear (very small) and it ripped wide open when I peeled it away from the body. I said a few words I won't repeat here, but didn't make it any easier. Truly sorry, I thought I could help with this. I did get the outer trim piece off, and the rubber seal from around the window of the passenger door. I will work on the rest in the morning when I get home from work, and on the driver door. Are you looking for both sides?
yep I would like to get both sides. sucks that the on pws on you. oh well i'll get it done somehow
I have all the trim off each door, and all are in pretty good shape. I stood the glass behind the trim when I took these pic's to show there are no marks on the glass. Everything was together very neat. No leaks, no streaks or scratches on the windows. PM me if you are interested in any of the pieces. Neither of the rubber door seals around the inside of the body are good, but everything else is fine. In the pic's I forgot to include the small adjusters for the inside of the window that mount to the door. They push out and align the window with the frame.
Hey...just a thought...have you tried to adjust the small bracket inside the door (under the panel and mounted to the top of the door) to be certain it isn't pushing too tight against the window and causing it to drag on your trim? I suppose this could cause it to mark the glass. No sense replacing everything if you can make it work.
I really need the outer window seal. That is why my windows are getting marked up. Here you can see it pretty well also you can see my toasted outter window seal.
Here are the pic's of just the pieces you want. Shipping postal service is $12, UPS is $23. Postal service OK? Total cost with shipping is $32. I will throw in the rubber seal that goes around the inside of both windows and call it $40 even cause it won't change the shipping cost if you want them. Anyway...
