Topic: Seeking help with a circuit design (Read 6513 times) previous topic - next topic
Very nice.  Basically the same ckt I used but I can see an improvement I can make.  :hick:
The simulator is neat but seems to be a little flaky if the wires aren't connected exactly.  The NPN in your example was misbehaving.
Can you also provide the part #s of the components you used?
tbirdregistry.com
26480
27373
Quote from: TheFoeYouKnow;394132
Special thanks to Thunder Chicken, your idea got me going in the right direction, and to jcassity, even though I didn't go with your simple version, it was very helpful to have somebody explain the finer points to me.  My final RC values were 549k ohms and 1000uF with a 10nF as the constant and 2.2k ohms between kill trigger and kill power to make the transistor act like a nc relay.  Somebody asked for a diagram when I figured it out, so here it is.
X
Love it. Nice work guys!
Quote from: rodsterh;394319
Yeah, a materials list would be helpful to us electrical noobs. :bowdown:
S5D, 2222 NPN transistors, 1000uF cap, 10nF cap, 549k resistor, 2.2k resistor, a large cube relay, a 2x4 project box and a 204-0006-01 schmartboard.  That's about it.  See the diagram I left a page back.
Just got a DEI 528T  unit to play with. Would hold for 1-90 seconds after door switch activation, then cut off. I THINK?
