Topic: Lug nuts (Read 3067 times) previous topic - next topic
Lug nuts
What the frick...I see many turbo coupes with 5 lugs...mine is 4..is it normal that my 87 TC has a 4 lug setup?? It makes it rather hard finding 4 lug wheels that are good sorta...
1987 Ford Thunderbird Turbo Coupe ~ STOCK
Lug nuts
The parts car I had was a four lugger.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Lug nuts
A stock TC will have 4 lug wheels. However, it's popular to swap in the spindles, rotors, calipers, rear axles and required parts from a '94 and up Mustang to get 5 lug.
I've done it to mine....mostly....
Lug nuts
If your okay with loosing abs, you can just swap the rotor.
Lug nuts
Quote from: Haystack;392084
I think my abs is screwed up anyways...I just thought it was something that sporadically changed or maybe something got screwed up somehow and I got a 4 lug because I could have sworn it said 5 somewhere..on a side related topic to abs, if that doesn't work is it just a computer issue?
Lug nuts
All Turbo coupes are 4 lug.
Lug nuts
Quote from: BlueBird1987;392151
SuperCoupes are 5 lug, but not the same bolt pattern/spacing as 5 lug Mustangs. Rather, they're the same pattern as Taurus/Sable/Continentals. Basically, the FWD Ford 5 lug pattern.
As far as ABS, it could be several things causing issues. Someone that's more savvy than I am can help with the Teves 2 stuff.
Lug nuts
Our fox T-Birds and Cougar ALL are 4 lug until we decide to convert them. Interestingly, our Lincoln cousin the Mark VII has the same chassis, but they came with lots of just better parts, including 5 lug axles, rotors and wheels.  Also on the better parts list are the engine (205-225HP HO vs 155HP? SO), headers, and H-pipe dual exhaust.  Like ThunderbirdSport302 said, however, most use mustang parts for the swap.
Lug nuts
Dont worry about the ABS the system is a piece of JUNK ANY WAY!!!
Lug nuts
okay so the lincoln had the same frame n stuff? so what if i say..find one of them and just swap it all? ;) sounds like A LOT of work...I'll just leave it as is
Lug nuts
Quote from: BlueBird1987;392523
That's actually what I'm in the process of doing. I have all the parts from a Lincoln, I took everything off the car worth using. Complete engine, the entire brake system, wheels, odds and ends. I just need the time to do it all. I really need a second vehicle, I hate working on the Thunderbird knowing I absolutely need it to get me to work the next day.
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
Lug nuts
Quote from: dragon574444;392529
I know right?? I need to replace the timing belt, and it's all sort of easy EXCEPT when we got to taking off the dang belt I realized I have to take off the harmonic balance and...dang no tools for taking that off and schucks has the wrong tool kit and...a large margin of error there...I just don't wanna take it to a shop to do it..that'll cost A LOT!!!
Lug nuts
I'd go sn-95 stuff, its getting cheap, and the 94-98 axles all have disks and are about the same length as stock. Plus down he road, upgrades are easy.
