Topic: Finally got my bird running again (Read 1273 times) previous topic - next topic
After probably close to a year I got my t-bird going again. It has set since I installed a Mass Flo kit. The issues were where I had my fuel regulator and a junk TFI they sent along with it. The TFI is what gave me the most trouble, it would start and have crazy idle, or it would be super hard to start. Finally I lost spark so thats what gave it away.
Only other issue I had is during idle a rocker stud snapped in half. No idea why this has happened, I have pics but can't get them to upload for some reason. (probably something to do with works firewall). Any one else had one of these break before? I wrote AFR since its their stud to see what they will say.
AFR sent me new studs, I'll swap out the mismatched one and all will be good. Think since the TFI had it running crazy it fired with the valve open and maybe that helped with snapping the stud. Not sure, will monitor it and make sure it isn't a problem.
It was good of them to send the parts to you. Hopefully that'll get you up and going. What's next on the list?
Finally got pics to upload :)
Next on the list is to fix the leaky c4 and drive it. Was running and driving till I decided I needed fuel injection lol. After that its some sort of trans with OD and QH. After I put some miles on it I'm thinking of getting a blower. We'll see how that goes.
