Topic: Maximum Motorsports strut tower bar hits hood. (Read 7315 times) previous topic - next topic
Sweet. Now for some CHE's. or did you do that already
The subframes made the most noticeable difference in the feel of the car. It felt much more solid after they were welded in. The strut tower brace makes the car feel a little stiffer in the corners and what little cowl shake over big bumps that remained after the subframes were installed has disappeared.
Quote from: sarjxxx;391560
Not yet. Building the 88 XR7 8.8 and getting torque box reinforcements so I can run slicks is next years project ;).
I want' CHE's bad. After seeing how much rear swing I've got, I hate taking turns now cause I can just see my control arms flexing and rolling in my head every time. eeeeeesh.
Quote from: sarjxxx;391565
You can box in the stock control arms really cheap. I have CHE's on the Sport. I was about to box the stock control arms and luckily, found a brand new set of the CHE's on Ebay for $50.00.
Sway bar looks very nice.  I had a MM carb bar I just sat on my car to eye it up.  It looked like it would fit, but I wouldnt be able to get to the charing ports on the AC.  If the car didnt have that I  would say it would fit fine.  Just a FYI.
Mike
The EFI strut bar I have hit the low pressure port on the A/C line. There is enough "give" in the metal line that I was able to push it back slightly by hand. It clears fine and the port can be reached. It's a good thing the line is a bit flexible.
