Topic: Hissing sound from my Colomn Shifter (Read 6504 times) previous topic - next topic
Hello all..Just signed up to this forum..As i picked up a 1988 T-Bird from old lady with 55k miles on it..Its 5.0 lx Auto Aod with column shifter..Unfortunately she had it sitting outside for 5-6 years vs garaged..ggggrr..Anyways..Ive had to spend a few buks here and there just to get it in a daily driver mode..After getting all my issues fixed..And runs very nice considering still stock..
Only problem is i have a sever hissing sound coming out of my column shifter..And when i pull the shifter forward to switch gears it gets more loud..When i drive and give gas..It goes away..But lay of the gas then the hissing is there..Has any one of you had or have the same problem..? Is it normal for these cars? Or is it as vacum leak of some sort..? Any help is much appreciated.As before i do and upgrade to my TBird..I have to fix all or any problems first..Thankyou
Sounds like a vacuum leak to me......does your car have the auto release parking brake when you put the car into gear?  I would start there......
Yep that's what it sounds like to me. Esp since when you step on the gas it goes away cause it loses vacuum when the throttle blade is wide open
Definitely a vacuum leak, either from the automatic parking brake release or from the brake booster.
The APBR plastic vacuum collar is located underneath the dash, on the end of the column, right by the firewall. It's white in color. You'll need to remove the underdash insulation panel to see it.
There's one nipple on the front side for the small line to the dash (gear selector).
IIRC there's another nipple on the other side. That's for the larger line coming in from the vacuum tee in the engine bay.
I've seen where that larger line splits so check that first. If you don't want the APBR or just want to test, you can cap off the nipple on the vacuum tee in the engine bay (it's marked B/R).
Otherwise you could have a bad brake booster. I've had one go bad and it will hiss just like that.
These should give you some starting points.
I would even play around under the dash,  just cap off b/r on the vacuum tree like eric mentioned and if it it goes away its fixed... I hate working under the dash lol
Quote from: MY83T;390512
No it does not..Are the 88cat/birds supposed to have that? Is that hissing sound maybe the reason it doesnt release?
Quote from: EricCoolCats;390519
That makes sense..Appreciate the feedback..Will check it out..Thanx
When you move the shifter and hear it getting louder, I would imagine that your foot is also on the brake pedal. With the engine idling, try slowly moving the brake pedal without touching the shifter and see if the sound changes in any way.
I suspect it's the booster. I had one start leaking in my '86 XR-7 and it drove me nuts.
Im curious. does the cruise control work? theres a little piece right around where the brake switch is on the peadl assembly that is adjustable. It is sopposed to create a vac leak when you hit the brake to kill the cruise. maybe its out of adjustment?
Just an idea?
I have this same problem on my 80 Bird, I will have to check these things since the dash is out right now.
Quote from: 87thunderbirdBlackJack;390578
Just an idea?
hMM..Havent tried ccontrol. yet..Will do..Thankyou all..This forum is awesome..
Quote from: INFAMOUSAPA;390547
Auto park brake release will not work if it has a vac leak. If the port on the vac tree under the hood labeled "BR" has a line coming off of it, you have this feature.
Just an idea?
Yes the Cruise Control does work.And my car doesnt have the break release..Ive done research on other forums..And it seems that its a rubber bushing that goes arond a moon shaped plastic part under the steering column..It has nothing to do with Brakes or Brake release..
My 88 LX has the auto release, so I'll bet yours does, too. Mine was the same way, I just unplugged the line and stuck a small bolt in it.  I'd be crazy to even use my parking brake, so an auto release is just silly.
Oddly enough my 20th had the BR capped off but does have auto e-brake release.
the little plunger is cracked on the side so i capped it off,, rarely use the Ebrake for anything.
take a picture of under your column, pictures are worth a thousand words.
