Topic: Turbo Buzzer and Dieing problem (Read 1313 times) previous topic - next topic
OK well I have to problems. One is the Check turbo light and buzzer are going off and wont stop. It happened after I hit a puddle of water. Car still runs the same as it did before. Two when I hit the gas hard and bring the rpm's way up then let off hard the car will die. Any idea.
i had the same buzzer problem and i just unplugged it its on the passanger side strut tower on the back of it unhook the plug not the vacume line (mine went bad).... as for the dying im not sure :(
I found it thanks. Now I just need to figure out the dying problem.
Check FUEL PRESSURE and scan for CODES!!
I looked for codes and nothing. Codes what the first thing I looked for when the turbo buzzer went off. I have not checked fuel presser. I just replaced the fuel pump and fuel pressure regulator not eve 3 months ago.
