Topic: My 85 TBird (Read 185050 times) previous topic - next topic
Re: My 85 TBird
Reply #285
That's one way to do it! You going to cover it in vinyl or leather?
My initial thought was to try to have one 3D printed. That’ll be plan “b”. Yeah, some sort of textured vinyl that matches the surroundings.
Re: My 85 TBird
Reply #286
After seeing it, I thought 3D  printing might be an option.  Might have to see if I can CAD something up.
It's hard to find them with those stupid mounting posts still intact. I don't think any of the ones I have onhand are unbroken.
Re: My 85 TBird
Reply #287
Mine still has both mounting posts, but all but 2 of the little posts for the boot retaining ring are all missing. I think I have some little studs left that I can weld onto this one with my stud gun dent removal tool, and shape up some mounting posts and weld them on. Should be plenty durable. :mullet:
I do think if someone were to design and print these it could be worthwhile.
Re: My 85 TBird
Reply #288
I’ve got more time in this than I care to admit, but a coat of primer and some vinyl and it may just work out. Vinyl should be here Friday, ordered 4 way stretch vinyl from Sailrite. The factory shift boot works with the opening moved.
Re: My 85 TBird
Reply #289
That looks pretty good! Looking forward to seeing the finished product!
Re: My 85 TBird
Reply #290
That looks amazing!  I almost feel bad that you are covering it up.
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
Re: My 85 TBird
Reply #291
Some console lid repairs. Both spots where the hinge screws on were broken. Roughed it up a little and used some 3M 8115 to remake mount.
The original plan was to use black interior paint on the lid, but I ordered plenty of black vinyl for the shift bezel, so I gave it a go. The first try failed because the upholstery adhesive wouldn’t stick to the original red vinyl. Some 80 grit on the DA and some hand sanding around the edges solved that. Few wrinkles but fairly pleased with the results. Hopefully it holds up.
Compared to the lid, the shift bezel was fairly easy to cover. Other than it sits up just a bit from the vinyl wrapped around the edge it turned out well.
Re: My 85 TBird
Reply #292
Looks amazing!
Are you planning on keeping the seat belts red?
'21 F150 Powerboost
'17 Husqvarna TX300
Re: My 85 TBird
Reply #293
Looks amazing!
Thanks!
I have the right color grey belts for the front retractable ones, and dark grey belts for the back seat, which I expect won’t see much use. These seats are temporary until I get the original red seats recovered, probably very close to how these look now. I have new fox mustang grey plastic covers on order from LMR, going to try to make those work for the belt latch part attached to the front seats. I think these red belts in the grey plastic covers are original to the cougar they came out of. Going to try to spray these red ones with the SEM interior paint I have once I get the new covers figured out.
I’ve got a 4 hour round trip planned tomorrow morning to pick up the windshield. Hopefully I get it home ok, I probably jinxed myself as I already have the local glass company scheduled to put it in Thursday afternoon.
Other than that, just been taking care of some loose ends here and there. Started final sanding on the header panel, I’ll be spraying that and the spoiler and a few smaller pieces when we get out of this deep freeze in a week or so.
Re: My 85 TBird
Reply #294
I'm pretty sure that they used whatever color for the receiver side in the Tbirds, as they were originally covered by the plastics.
I've run into red or other color receivers on grey interior cars a few times.
Re: My 85 TBird
Reply #295
Keeping my fingers crossed for you on the windshield.
'21 F150 Powerboost
'17 Husqvarna TX300
Re: My 85 TBird
Reply #296
Got the windshield home without issue. I increased my odds by taking my Moms Subaru instead of my old f150, I’m sure the crossed fingers didn’t hurt either.
Re: My 85 TBird
Reply #297
Windshield installed!
A fender too!
Re: My 85 TBird
Reply #298
Oh My!!!!!
'21 F150 Powerboost
'17 Husqvarna TX300
Re: My 85 TBird
Reply #299
Temps are finally out of the deep freeze and on monday I was able to do some painting , sprayed the header, spoiler, fuel door, hood scoops and headlight bezels. Some sanding and buffing on the header and spoiler on Tuesday, and some assembly yesterday and today. Hopefully get the bumper covers, grille, and headlight covers prepped for paint this weekend.
The tempo window runs seem to fit really well with some careful trim work where it meets the belt moulding and vent window. The 80-96 ford truck window run was a perfect match for the vent window section. I did a little experimenting with the Tempo runs to see if they would work on full window cars, I think there is some potential there.
The cut out is where the tempo run changes directions and runs down the front of the door. The cut out allows it to lay flatter in the tbird door to reach where it changes direction. I didn’t spend much time trying to get the angles right for a better splice at that point but I think it would be doable. Not sure if that notch will create a wind whistle, but maybe some careful urethane work would seal it back up.
