Topic: headers (Read 3121 times) previous topic - next topic
headers
ive got a 351w in a 88 tbird and the headers that are on the car really dont fit i had to crimp them on the drivers side to get them to fit by the steering rod. does anyone know what a good set of headers to put in there would be.?
headers
I got a set of summit brand long tubes for my 302, may check them out and see if they have a 351. Its tight but they clear everything.
headers
Is it the large round part of the steering rod thatshiznitting the collector part or the shaft itself.  I put an aftermarket shaft in cause it rubbed on the bbk longtube with chucks motor mounts.
headers
its the shaft part.
headers
How much is it rubbing?
headers
its barley rubbing but when i turn you can hear it and the shaft is showing some wear ive heard of people using headers that wrap around the steering colum has anyone does this?
headers
What heads and what headers you have?
headers
there stock 1970 351w heads and the headers are made from hedman but idk they where on the 5.0 when i bought the car.
headers
thats why they hit,  they are designed for a 302 and are bent to fit that combo.  The added deck height of the 351w is screwing you up, You need to just put headers designed for a 351w on the car
headers
Quote from: Bob;389622
Which is why we've all posted links to bbk swap headers.
headers
My headers wrap around the steering column, you have to cut the  and turn the pipe, put in and tighten down. That last pipe being kind of independent from the other 3 make it interesting when starting bolts..
headers
okay im just trying to clerify i wanted to make sure smeones has put a 351w in thre tbird and used headers that just fit right in so your saying theese bbks will do that?
headers
Are you sure the motor is centered correctly on the mounts?
