Topic: First Time Drifting (Read 21073 times) previous topic - next topic
First Time Drifting
i'm not sure if TCI makes a manual VB for AOD's, but there are plenty of companies out there that do.. in all honesty though, a pro stick would be much more sufficient for fast down shifting.. i'm a little biased, as i loooooove my pro sticks in my blue TC and capri.. but the pull back lever allows me to throw the shifter down into lower gears in a split second, instead of pulling up on a t handle before downshifting, which is effectively slower
First Time Drifting
I don't have to pull on a lever to downshift. That's only for reverse lockout. Once you put the Megashifter in drive its in ratchet mode. Its kinda like driving a tiptronic. You click it forward to upshift or back to downshift.
First Time Drifting
what the hell.. my old mega shifter wasn't like that.. of course, we're talking about 8 years ago.. lol
First Time Drifting
A few pictures of the bushing project.
the bushings slide out easily after a little heat from the torch.
One of the lowers.
After a little cleaning up and new bushings
back in
an upper control arm and my rear sway bar being painted
I used a vise to press the bushings in
First Time Drifting
It's too bad you couldn't have boxed those in with openings for the sway-bar. Looking good anyway.  :burnout:
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
First Time Drifting
I was thinking about boxing them, but i think im gonna let a panhard bar handle the lateral force on the axle. That will be my next project.
First Time Drifting
That CA looks better than new!, Nice work!
First Time Drifting
Thanks. A couple more pics.
My strut brace came in. It doesn't look like it will work with any of the pre-threaded holes, so that will be tomorrows project.
First Time Drifting
The brace is in and the car is now officially ready for saturday!
First Time Drifting
Reply #39
looks like it baaaarrreeely fit around that manifold in the front whew
First Time Drifting
Reply #40
About an inch to spare.
edit: it was only like 3/8"
First Time Drifting
Reply #41
Forgot to mention, the car feels awesome! I waited till the bushings and brace were both in to drive it and it was a very noticeable improvement. Car feels a lot stiffer, stays more composed on bumpy corners, and corners harder than before.
First Time Drifting
Reply #42
Sweet!! Glad it's working good for you. Like the way you car looks :D
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
First Time Drifting
Reply #43
Thanks 1badbird. I've been following the progress on your autcross project. I will be switching to a TC header panel as soon as I can get my hands on some inner lights.
First Time Drifting
Reply #44
Ive been wanting to get bushing for mine, I already have front poly bushing. It really made it feel tighter. Nice intake, do the make one for the GT40 lower?
