Topic: A few upgrades: 5/20/13 Pics outside the garage! (Read 52559 times) previous topic - next topic
Reply #225
iv farted around you tube and seen some vids .........you got a nice car man
Reply #226
That color is amazing! Love the ride height on it too! Amazing!
Can't wait for more pictures! I'm thinking about my bird every day now when I'm in China for work :P
By the way, I can't really find any used 4.25" pulleys so if you still have your 4" I might be interested in it! Send a PM if you still have it :)
Reply #227
Quote from: Thunderbird88;415982
Thanks!  I sent you a PM on the pulley.
Reply #228
Took the car out to it's first showing (thanks to Kevin's invite!).  Things went well, till the ride home.  Made it home with the fuel pump cutting out intermitently (this has been a nagging issue since first start up).
Good news on two points:  Made into the garage before it quit completely and the other, more importantly:  It's finally failed (so I can trouble shoot it once and for all!).
Reply #229
I always love when something on the car waits to fail till you get home. It's like the car doesn't want to end up on a flat bed.
Reply #230
Hey Mark
Sorry to hear about the pump...but you suspected that could be a possible problem.
Its only time and money... ;-)
Travis
Reply #231
Quote from: turbotrav;416555
Hey Mark
Travis
Don't think it'll be much on the money end (at this point...), it's the time that's killing me!  I suspect it'll be something simple: a ground, maybe the inertia switch.  It's clearly an open.  Just have to locate it.
Reply #232
Be happy mate, atleast you aint stuck in communist china with a broken car back home ;)
Reply #233
Fixed two issues today for just about $110.  Took care of the lack of fuel pressure and the fuel gauge!  Wasn't too tough.  Had to chase out for stuff twice, the first one cost me $20 and fixed the fuel pressure.  The second trip was just under $90 and it fixed the fuel gauge.
All it took was 24.5 gallons of 93 octane (@4.49 per gallon)!  4.5 gallons in a can, added to the tank and it fired instantly, and then drove the car to get it filled up.  Yup, feel like a dumbass.
As I've been sorting out various issues, I had added 5 gallons of fuel twice.  Made the assumption, that the fuel gauge wasn't working, as the gauge didn't budge either time I added fuel...
Apparently ~30' of -8an fuel line & aftermarket fuel rails push the fuel capacity by another 2.5 gallons.
Thankfully it ran out pulling in the garage.
It's developed an oil leak, which may keep it from making any road trip year.  Will need some dye to track this one.
Reply #234
Didnt the bird have a major oil leak last year?
Travis
Reply #235
Quote from: 86T-bird;416795
Uuugh! :punchballs:
Reply #236
Quote from: turbotrav;416803
Didn't the bird have a major oil leak last year?
Travis
Yup, the first assembly, oil was puking out when I primed the engine.  Pulled the engine, replaced the rear main, put a new pan on it, installed support rails on the pan to ensure the pan didn't get tweaked.
Round three:  The back on the intake did not seal on initial start up, but that was a simple fix.  After that it idled for hours with no sign of a leak...
It leaks under pressure.  It pushed out a quart in ~80 miles.  Made a hell of mess under the car!
Can't say this is a smoking gun, but there was no leak until I changed the oil & put in synthetic.  It's possible something else let go or failed.
I'll search out some oil dye, which shows up with black light.  That'll help identify where it's coming from, but the trans, clutch & block plate will need to be pulled as a starting point to see anything.
The dual clutch was hell to install.  Could only mate the engine to the trans with them both out on the floor (found that out after putting the engine in...).  I'll pick up a 10 spline input shaft, to make the process easier, the plastic splined guide tool that came with the clutch assembly must have a slight variance, which prevents the trans input shaft from sliding into the clutch disc's.
I took it to a car show in Livonia on Sunday.  It got a lot of attention!  Though I'm getting pretty weary of working on the "details", it did give me some encouragement!
Reply #237
Quote from: gumby;416835
Uuugh! :punchballs:
A punch in the balls would be easier to get over!
Reply #238
Engine & trans are out.  Cleaned the back of the engine and then tilted it tlo flood the back of the engine with oil, looking for a clear sign of the leak.  This revealed the rear main as the culprit!  The seal itself looks fine, there are no nicks or problem areas visible on the seal or the crankshaft.
I'll call the guys at the machine shop to see if they can offer some insight.  If it's possible to get this thing to seal (we'll check it the same way, once it's back together), with the help of my friend Mike, we plan to thrash and get it back together by the weekend.
Reply #239
You could try one of those speedysleeve's.  Its pretty much a repair kit for the crank to repair the wear grooves in the sealing surface.  However, you probably have a brand new crank which should've been fine.  Just a thought
