Topic: window off track and stuck down!!! (Read 1775 times) previous topic - next topic
So my window fell off its track today! i am taking the door apart to get to it but i cant figure out how to take the top of the door panel off! i got the arm rest and speaker guard off and i got the lower door panel popped off but i cant figure out what is holding the top of the door panel on!
The top slides up, I am sure you took loose the screws for the pull strap.
That is the worse thing with the TCs door panels,  you have to completely disassemble them to take them off!
...and there was light!
You have to pull upward on the door panel.  Just make sure you have all the fasteners out and it should pull right up.
Thank you for the help. I got it back on the rollers to have it stay up but whenever i roll it down it doesnt follow like something is rubbing up against it not letting it go down. Any ideas.
You have to glue it in the mounts. Window weld works very well for this and is available at any auto parts store.
Auto body urethane or aquarium glass silicone.
okay thank you very much for the help!
