Topic: fiderglass removal (Read 3456 times) previous topic - next topic
fiderglass removal
if you want a quick, temporary fix, use jb weld.. i'd recommend denting a small area around the hole, so you can sand it and spray some primer or paint over it.. i wouldn't recommend this as a permanent fix.. permanent would definitely be weld them, grind down the weld and spread just a touch of filler over them to smooth everything out
fiderglass removal
this is the stuff that was hold the fiberglass panel to the roof. it has a rubbery feel to it and i dont know how to remove it...srri im so late at getting tese pics up..
fiderglass removal
its also on the inside quarter panel windows
fiderglass removal
it's some sort of butyl.... razor blade looks like it will work... keep it flat to the surface, and it shouldn't dig into the paint
fiderglass removal
ok ima go out and give that a try..
fiderglass removal
if a ravor blade still digs into the paint, try a plastic putty knife/ser.. it may leave a little behind, but you should be able to get the last of it off with acetone
fiderglass removal
thats was gonna be my next question lol. the razor blade worked great. so acetone shoukd be used to get the thin layer thats lwft behind off?
fiderglass removal
yes that should clean the rest up
fiderglass removal
i'd put some in a spray bottle, spray it on there and let it sit for a minute.. then with a little elbow grease, it should come right off.. it'll probably leave a little residue behind, but you can just spray it again and wipe it down to get the last of it
fiderglass removal
ok ill have to do that in the morning
fiderglass removal
thank ypu guys for your help on this. just took the first little step to breathing some new life into my old girl
fiderglass removal
that's why this forum is here ;) needless to say, you're very welcome.. anything we can do to help a bird/cat keep breathing!
