Topic: air pump questions (Read 837 times) previous topic - next topic
air pump questions
hi
would you guys replace an air pump and the air valves on a 1984 3.8  just to do it since other things are apart now? i have never heard of anyone saying that their air pump went bad, not that it couldnt happen, im just thinking is it an expense that is worth it, like will it make the car run better or better mileage?
since its a 29 year old car i was just thinking.
eddie
my rides well some of them work:hick:
1995 towncar in black 246 K non running
1989 continental 110K waiting for a part
1984 cougar head gaskets done almost ready!
Yikes the daily ride ...1998 chevy lumina:hick:
air pump questions
i assume you're referring to the smog pump? give it a spin and see if you hear any bearing noise, grinding, etc etc.. then give the pulley a jiggle up and down, then in and out to see if it has any play.. if the bearings are still good with little to no play, you should be in good shape.. i don't believe they have any real effect on gas mileage, as it's mostly for emissions
btw, where in nj do you hail from? just curious
air pump questions
well the pump is no good wont move at all. im going get another. found a new old stock one for $150 or i can get a cardone rebuilt for $80 . not sure which way to go. also  now i need a bracket that the air pump and alternator mounts to. it snapped off down by the air pump. anyone have a parts number for that bracket ?
shadow im up ramsey new jersey just up the highway from paramus new jersey { they say is the shopping capital of the country }!!
eddie
