Topic: Fresh Pics (Read 2007 times) previous topic - next topic
Fresh Pics
I've got some fresh pics for ya'll. Even though I need body work I waxed the car with Meguiers NXT tech paste wax and buffed it off with a Random orbitl buffer first with terry bonnet they with a foam bonnet. Shines where it can. Also I recently installed A/c on my bird so I took a current pic of my engine compartment. I also added a homade gills valve and boost gauge and a Oil pressure guage.
Re: Fresh Pics
Also need some help with my vac line setup do I need both of these check valves? I just hooked up my Vac/Boost gauge and I show no vac at idle.
Re: Fresh Pics
you need the check valves, its for your cruise control to work properly
hook your boost/vac gauge to an empty barb on the vacume tree, the one with the blue cap should be good for ya, if not, the other one there
how is your gillis plumbed in?
