Topic: Tons of parts for sale (lots o pics 56k beware) (Read 3403 times) previous topic - next topic
I took invintory on all of my surplus of parts and decided I needed purge some things seeing how I only own one fox tbird... and enough parts to build 3 or 4 it seems like.
All parts are located in Fort Wayne, IN 46818
1 raven console it has the front tabs are broke off and the front center bracket is broken too. the cubby and rear mounting bracket comes with. $25
TC inner lights Buy all 3 I had 4 but upon removal I noticed the entire bottom side of the passengerside inner was gone. $30
Set of red visors theyre a little dirty but no rips $10
8.8 disc brake brackets dust shields are fudged up but can be tweaked.. $20
Passenger side mirror needs painted but otherwise decent $15
premium fuel switch- $5
window switch$5
I have no clue what this is... $5?
Seat switches $5
Stock base instrument cluster $10
Brushed radio surround for console car $10
cassette holder $5
Brushed radio surround for consolette car & matching ashtray peice $20
Woodgrain radio surround for consolette car with matching ashtray $20
Dash trim Woodgrain or Brushed $15 ea
1 Dual power seat switch panel $15
1 non-autolamp switch plate$5
1 autolamp switchplate$5
2 passenger side mirror covers 1 driver side $5 each
1 EQ with the power button switch problem. $5
1 Radio $5
1ATC $5
1 system sentry$5
2 Clocks $5 each
1 trunk/fuel door switch $5
1 non console ashtray $5
1 Console ashtray $5
1 Console lid cracked and no button $5
1 radio pocket $5
1 big handfull of seat track cover peices all for $5
Gas tank straps $20
TC dual fans $30
Red apillars $15
Tbird taillights Could use some polishing but other than that they are all in one peice and very nice $45
Dash cover..Its in nice shape. can be dyed I suppose. I set it in my car to get an idea.. $make offer?
I have 3 sets of headlights. They have a tidbit of yelowing to them and one set has a lose backing bracket but it doesnt move much. $30 each set.
Finally. a very nice TC header. It has the usual stone and paint chips bla bla but is a very nice peice. $65
Thanks for looking!
Quote from: 87thunderbirdBlackJack;382522
I think, not entirely sure though, that the lights on the right are for maybe a cougar or something? It might just be the angle of the picture, but it doesn't look like a T-Bird light? Just don't want you to have to go through a shipping nightmare.
Great looking header panel! GLWS!
...and there was light!
Well I went out and looked. You sir have a very good eye.. I did have a cougar parts car at one point in time.
So I for sure have TWO sets of tbird headlights and ONE set of cougar headlights.
How much for the shifter cover shipped to 27127? any broken tabs?.....PM me
Will the TC fans bolt in a Sport??  If so, may be interested.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Do you still have the tail light sections and the duel radiator fans?
PM sent
ttt
still have everything. Everything is OBO
I am increadibly interested in your TC header and the best set of headlights you have, and the inner passenger light.
Alrighty PM sent
what condition are the seat track covers and the power seat control panel in?
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 3.8 V6 - Rescue
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 5.0 V8 - Survivor
Do you have intercooler mounting hardware?
I have a 1988 TB Turbo Coupe.  are the duel fans still avaible and also the tail light Assembly?  I am also looking for a headlight module ( the dash board dimer and head light control).  Do you happen to have one.
v/r
Richard
flgypsysoul@gmail.com
Quick question:  Are the TC inner lights the same as the non-TC inner lights?
If so, then I could use a passenger side inner.
Quote from: cobrajoe;401584
No, the TC one is a bit wider at the base.
1988 Thunderbird Sport
