Topic: Point of no return (Read 11354 times) previous topic - next topic
Point of no return
In the 80's and 40-50 mph winds in New Orleans today. I get to go offs early in the morning, lets see 40 mph winds, boat ride to the rig, I should be good w/Dramamine
1988 Thunderbird LX  557/C6 project. UPR tube K-member, A-Arms, Strange 10 way adjustable coilovers. SN-95 spindle,brakes. Manual rack, bump steer kit.  MM castor/camber plates, Dynatech 2 1/8 swap headers. Quick 9" 35 spline Moser axles,CHE lower c arms,
Point of no return
Bought my front rims and tires today. Might be up to a month getting them if Weld does not have them in stock.
http://www.jegs.com/i/Mickey+Thompson/672/6652/10002/-1
http://www.jegs.com/i/Weld+Racing/927/71MB-504A15A/10002/-1
Point of no return
I want to get a pair of the 26X10 for my turbines. They say they'll fit 7" wheels.
I love those wheels too, just not for that much $.
Point of no return
Yes$$, Im buying 2 at a time! I need to buy a centerchunk for the differential, get that bolted up and buy 2 back rims and tires. Then the car will be trailered back to New Orleans to get my chassis welding and cage done.
Point of no return
What tires are gonna run in the back?
Point of no return
Im unsure right now, some type of drag radial. 295 or 315. Pretty sure I will mini tub the rear. I like the m/t  matching rears to my fronts.They look nice.
Point of no return
83-88T-Bird Guy had 325/50/15's on the back of both is red bird and grey bird. with a 6.5 offset and no tubs.
Thats what Im going to run on my bird when I get it close to being driveable.
Point of no return
My differential is about 58" hub to hub, a little more narrow than stock.
Point of no return
Quote from: V10KLZZ71S;385012
Thats what I want, the 26X10 M/T rears.
Point of no return
Reply #39
oooooooow.. the RT-S's.. sooooo shagy
Point of no return
Reply #40
Im going with Ron Francis wiring stuff to rewire my 'bird. I really like this switch panel to simplify things.
Point of no return
Reply #41
Wow you are going all out strip car with this one huh.
Point of no return
Reply #42
Drag car that is barely street legal. I have decided to go with a full spool in the rear. That can be quite fun in the rain. I did own a 67 mustang when i was 17-18 yrs old with a mini spool on the street, worked fine.
Point of no return
Reply #43
people cry when you say you're running a spool on the street.. it's all good and dandy, as long as you're not running stock axles and like making super sharp turns lol
and GO FAST OR GO HOME! :burnout:
Point of no return
Reply #44
Can I buy your A/C - heater box off you?  I have auto-climate and I want another one for insurance. :)
I really like your build!  Thanks for sharing the pictures and progress with us!
