Topic: Carb breathing 86 bird (Read 5466 times) previous topic - next topic
Have a 86 ford thunderbird base model that cam with that good ole 3.8 v6
Swapped in a 73' sbf 302 motor. ( i like the old school stuff ;)  )
302 has been modified but am now working on a 331 stroked short block.
Goin old school is kinda a pain in the ass sometimes but i gotta say it sure does turn some heads when everyones expectin a 5.0 then they see the air cleaner sticken through the hood on top of a holley. Gotta love the sound too lol
If anybody is thinkin of doing the same thing, go for it. Everything pretty much fits right in. Except i had clearance issues with the steering shaft even with using fox body shorty headers?.......
1986 Ford Thunderbird
!!COMPLETED!! 427 ci ROUSH engine swap<<!NEW! Fed by a Holley Terminator EFI setup/ custom COP setup ignition
 8.8 rear. with 4:10 gears, Eaton Trutrac diff, 31 spline axles and external breather system. Had it cleaned, sandblasted, and powder coated.
Holley Terminator EFI with custom made CNP ignition system
"Its kind of like driving the red headed step child of the mustangs" :hick:
Seems most shorty headershiznit in the  steering shaft area, long tubes fit much better around that area. i also offer throttle cable kits for carb swaps
Yup, kickin myself in the a$$ for not geting long tubes. But i actually do need a whole new cable setup, wutcha got?
I'm thinking about doing that with my 88 Bird myself but going 351w and tubular K member and long tubes.
Just a FYI: if you have a 302/5.0 the FRPP stainless shorties clear the steering shaft fine.
tube k-member, carbed 302, and longtubes all works really nice together
Quote from: cougarbird86;380358
aaah, someone else who prefers a carb.. my old sport and my black TC were both carb'd 306's.. really cleans up the bay :)
How did you do your fuel system? In-tank pick-up, or sumped tank/fuel cell?
I went "old school" also.......................keep it simple !!!
Look at all these carb breathers....Im lovin it!!!!
It really does doesnt it?! Clean and simple......until the carb needs adjustment ; )
Right now i just have the stock tank and pump going to a Mallory 3 port regulator that can withstand the high fuel presure and tune it down to only 6 psi for the carb. When i do upgrade it, i will probably run a fuel cell with an external pump or something like that.
Nice!!!
