Topic: My new braking set up (Read 1785 times) previous topic - next topic
Ordered all of my parts today to redo my braking set up.  The car is a '88 Sport Coupe with TC rear, stock front 10" brakes, TC prop valve, and stock MC.  With this set up I never could get good brakes on the back at all...you had to be super careful driving it b/c the front would lock up very easy.  During my current tear down I also swapped out the stock fronts for TC 11" brakes.
Today I ordered a 1985 Lincoln Towncar MC (1" bore).  From the LTMC I'm going to run all new copper ferrous lines with the front brakes going through a "T" fitting to split them and the rear brake line through a Wilwood Manual prop valve and eliminate the TC prop valve.
I'm hoping this simple approach will work....I've read SO MANY different threads about various combinations of swapping boosters, MC's, PV, and this or that will or won't work that I just decided to go basic and see if my own blend of components will do it.  Going to start bending lines next week and getting them system plumbed.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Copper for brake lines? Is that safe?
Seems that the Linc Towncar MC is the better one, I've seen it recommended over the '93 Cobra, because of the 3-into-2 setup..
Pics please :)
Quote from: ThunderbirdSport302;380277
Copper for brake lines? Is that safe?    Pics please :)
Copper Ferrous....completely different animal than copper lines.
Pics....will certainly do when all the pieces are here and ready for assembly.  I'll link this thread to my rebuild thread when I get a chance to update it.
The stock proportioning valve is part of the combination block which also houses the shuttle valve.  The shuttle valve is a safety switch which will cut off the flow to either the front or rear brakes in the event of a line failure.  This alone was enough of a reason for me to keep it on both of my cars and just gut the factory proportioning valve.
The stock proportioning valve will need to be modified if you go to rear disc or to install an adjustable proportioning valve. You will need the FMS part: M-2450-A and an adjustable proportioning valve to complete the modification. The stock PV is housed in the front part of the combination block.  This block is under the master cylinder and houses the PV and shuttle valve or pressure differential valve.
X
Why do you need to modify the valve? Because it is designed for the specific car and brakes that come with it off the assembly line. So if you change to different size brakes, you will need to change the front to rear bias via the proportioning valve. If you do not, then you will not get the most braking capability out of the car. Worst case scenario, you have too much rear bias and the car spins around when the brakes are applied. Not good on a rainy night!
If you have a Sn95 PV, why not use that?  For the same reason you are not using your stock PV.  It is not setup correctly for the amount of bias you need.  The Sn95 valves are setup for the Sn95 car's weight, braking system and bias requirements.  If you do find a 94+ car without ABS or 79-86 , you will notice that they are setup for a 2 port master cylinder.  You can swap the end nuts on the combination valve and use this fitting as long as you cut and flare the nut from the donor car to make a factory like 3-2 conversion!  You will not find those size of brake nuts at any parts store!  Alternatively, you can remove the front internals and cap and transfer that to the fox3 combination valve and that will work to the Sn95 bias specs. This may not be the best bias for a fox3 car, but will work.  The solution is to defeat the stock PV by gutting the unit and running an adjustable valve.
Okay, so how do you "gut" this proportioning valve? You use a 13/16 wrench and take the front cap off of it. Be careful as once it is loosened, the spring will shoot it out! Then remove the spring, the spring seat and rod. You may need some needle nose pliers to remove the rod from the valve. Do NOT remove the rear spring and rod from the rear of the valve. If you do modify the rear of the valve to work like the FMS M2300K kit or tap the rear for the 3rd port, be sure to install the rod and spring back in there!
Once you are done modifying the stock valve, you need to install an adjustable unit. There are two kinds of adjustable units:  style and lever style. The lever style is more designed for an in-car application so that you can adjust the bias as the tires and brakes wear down in a race. You want the  style. To install it, remove the coupler along the passenger side firewall and replace that with the valve.
When you bleed the brakes, adjust the valve all the way in for the maximum rear pressure. Once done, adjust the valve all the way out, and then in 4 full turns for your initial setting. Adjust in 1 turn increments from there and then half turn increments to fine tune. You will feel the braking and the pedal differ as the bias is changed.
Darren
