Topic: fuel pressure (Read 1953 times) previous topic - next topic
fuel pressure
can a mustang 5.0 BBK fuel pressure regulator bolt right up to the stock 2.3 fuel lines? Mine came with it so im not sure but my friend wants to know for his car?
fuel pressure
I believe it will,  but make sure it's a rising rate regulator, or it'll create severe problems.
fuel pressure
How can you tell if it is a rising rate regulator?
fuel pressure
Has a vacuum source on it.
fuel pressure
This is the one
http://www.latemodelrestoration.com/item/BBK-1706/1986-93-Mustang-50L-Bbk-Adjustable-Fuel-Pressure-Regulator?utm_source=google-shopping&utm_medium=comparison-shopping&utm_campaign=google-shopping
fuel pressure
it doesnt say anything about a rising rate but it looks like it has a vacuum source
fuel pressure
It should work fine, if it bolts up. If you need a new regulator I'd just get a Motorcraft replacement one. The computer will eventually tune out any increase in fuel pressure.
fuel pressure
it looks the same as the others but it just doesnt say it has a rising rate like this one.
http://www.sparktecmotorsports.com/am-13103.html
They look the same minus the color to me pretty much but the BBK doesnt say rising rate.
http://www.stage3motorsports.com/product/BBK1706/1986-1993-Mustang-GT--LX-50L-BBK-Adjustable-Fuel-Pressure-Regulator.html?meta=GBASE&metacpg=BBK1706&utm_source=gbase&utm_medium=CPC&utm_content=&utm_campaign=BBK1706
fuel pressure
I just checked with BBK and it is a raising rate one
